At 12:19 21 July 2014, jherzog wrote:
I have an Oudie 2 coupled to 12V power and exchanging data with an LxNav Nano using the cable kit that comes with the Oudie. I experienced significant radio noise -- usually enough to break the squelch. I saw a prior posting by John DeRosa, who recommended this inexpensive yet overpriced ferrite choke core from Radio Shack: http://www.radioshack.com/product/index.jsp? productId=2103222 I installed it around the Oudie power/data cable, about 1/2 inch from the Oudie-side of the cable -- I have had no radio issues since. -- jherzog Thank you to all for replying. I will try this solution first and report back. Doug |
On Monday, July 21, 2014 11:36:41 AM UTC-7, Doug Mueller wrote:
At 12:19 21 July 2014, jherzog wrote: I have an Oudie 2 coupled to 12V power and exchanging data with an LxNav Nano using the cable kit that comes with the Oudie. I experienced significant radio noise -- usually enough to break the squelch. I saw a prior posting by John DeRosa, who recommended this inexpensive yet overpriced ferrite choke core from Radio Shack: http://www.radioshack.com/product/index.jsp? productId=2103222 I installed it around the Oudie power/data cable, about 1/2 inch from the Oudie-side of the cable -- I have had no radio issues since. -- jherzog Thank you to all for replying. I will try this solution first and report back. Doug Doug, What brand of radio? Richard www.craggyaero.com |
Richard it is a Dittel. The problem only started when installing
the Oudie 2 to the ships power. Doug At 00:05 24 July 2014, Richard wrote: On Monday, July 21, 2014 11:36:41 AM UTC-7, Doug Mueller wrote: At 12:19 21 July 2014, jherzog wrote: I have an Oudie 2 coupled to 12V power and exchanging data with an LxNav Nano using the cable kit that comes with the Oudie. I experienced significant radio noise -- usually enough to break the squelch. I saw a prior posting by John DeRosa, who recommended this inexpensive yet overpriced ferrite choke core from Radio Shack: http://www.radioshack.com/product/index.jsp? productId=2103222 I installed it around the Oudie power/data cable, about 1/2 inch from the Oudie-side of the cable -- I have had no radio issues since. -- jherzog Thank you to all for replying. I will try this solution first and report back. Doug Doug, What brand of radio? Richard www.craggyaero.com |
On Thursday, July 24, 2014 10:52:30 PM UTC-7, Doug Mueller wrote:
Richard it is a Dittel. The problem only started when installing the Oudie 2 to the ships power. Doug At 00:05 24 July 2014, Richard wrote: On Monday, July 21, 2014 11:36:41 AM UTC-7, Doug Mueller wrote: At 12:19 21 July 2014, jherzog wrote: I have an Oudie 2 coupled to 12V power and exchanging data with an LxNav Nano using the cable kit that comes with the Oudie. I experienced significant radio noise -- usually enough to break the squelch. I saw a prior posting by John DeRosa, who recommended this inexpensive yet overpriced ferrite choke core from Radio Shack: http://www.radioshack.com/product/index.jsp? productId=2103222 I installed it around the Oudie power/data cable, about 1/2 inch from the Oudie-side of the cable -- I have had no radio issues since. -- jherzog Thank you to all for replying. I will try this solution first and report back. Doug Doug, What brand of radio? Richard www.craggyaero.com I believe it has an auto squelch Depending on the age of the transceiver it has a squelch threshold pot (it is very sensitive) either internally or for later models in the setup software that has to be adjusted upwards. The Becker is similar for the Becker you need to look at the installation manual for instructions. Not the operating manual. Richard www.craggyaero.com |
Oudie Issues | vontresc | Soaring | 4 | July 16th 14 04:44 AM |
Why bother about light aircraft noise. | [email protected] | Piloting | 36 | July 13th 05 09:52 PM |
Newer aircraft mx issues | SAC | Owning | 4 | July 6th 05 05:59 PM |
Couple of Plugs: Stan Shannon and Wicks Aircraft | Larry Smith | Home Built | 8 | November 8th 03 01:22 AM |
ISO back issues Combat Aircraft magazine | mark e digby | Military Aviation | 0 | August 12th 03 05:39 PM |
