Hard to assemble glider
Old July 21st 14, 07:54 PM posted to rec.aviation.soaring
Default Hard to assemble glider
Insert the right wing first and tape at least the top joint. Then insert the left wing. Here is the trick. Open the canopy as the wing goes in you can easily see the alignment of the two spars and most importantly the relationship of the spigot to the hole in the right wing root. So now it is easy to get the alignment just right. If you do what it says in the manual and insert the left wing first, you can't see where the alignment problem lies. Also I suggest the flaps be in 0 and the spoiler handle in the middle. Always confirm the water dump is closed. If the dump is open, you will never get the wings on. Finally, speaking of water, if you have an issue with leaking dump valves, use the wax sold in hardware stores for sealing toilets.
Bob
Ventus C
On Monday, July 21, 2014 11:40:50 AM UTC-7, HGXC wrote:
Hi
I fly a older Ventus and my glider wings are difficult to slide tight to the glider for pinning.
I have a 1 pin set up and start with my left wing. I keep my brakes open and flap in 3.
I can line up the inserted arm fine and line up the controls but, once I get to a couple inches it bogs down and is quite a workout for my wing man and me.
Any tips or suggestions on making this easier? I notice that even on the same glider type and model they can vary on ease of assembly.
Dennis
How hard is a Diamant to assemble? Spam Soaring 18 July 5th 15 02:54 PM
U2: Big Glider; hard to land [email protected] Soaring 1 March 16th 09 09:15 AM
Do you assemble your glider paying good attention to it? [email protected] Soaring 6 January 24th 07 10:48 AM
Do you assemble your glider paying good attention to it? Steve Leonard Soaring 0 January 23rd 07 12:53 AM
A&P signoff required to re-assemble 1-26? [email protected] Soaring 5 July 13th 05 05:32 PM
