Dennis,
There is the tube that is the airbrake handle. It slides over another tube which is basically a guide. If you open the airbrake handle 2-3 inches you should see that the guide tube has a roughly 1/4" diameter hole drilled in it. You can put any metal rod in this hole and it will prevent the airbrake handle from moving forward to the full closed position. Many people use the tail assembly threaded tool. With the airbrakes held partially open, you won't be fighting the airbrake over-center lock when you push the wings together. The next thing is to make sure that the end of the spar of the first wing is centered vertically in the opposite spar cut out and is aligned forward/aft and up/down such that the pin on the end of the spar will line up with the socket in the opposite root rib. The last trick if you can get the wings to start to go together (end of spar pins are engaging the root sockets) is to use a metal pry bar to pull the wings together the last 3/4". To make one of these pry bars, go to lowes or home depot and buy an 18" piece of 1/2" round bar. Use a grinder and aggressively grind one end so that it starts to look like a flat blade screw driver. Be sure to remove any sharp edges. Cover the bar with a piece of tygon tubing except for the last 1-2". Be sure the last 2" are well rounded and very smooth so you don't put any marks on the inside of the main pin bushings. When you can see the aft main pin bushing hole through the near bushing, insert your new rigging tool and you can lever the wings home with minimal effort. Mark |
I found with the Ventus and Nimbus it is good to clean the pins on the end of each spar root and wing root should be cleaned with 00 steel wool every few years and then lubed carefully. The spherical bearings on the fuselage and on the wing roots should be cleaned until they move freely. They can be rotated and removed if installed correctly (incorrectly and they go into the tubes). Q-tips and solvent will help free then up.
I have found many ships have never been cleaned in years. Usually the tightness for the last 1/4 to 1/2 inch are from lack of cleaning as long as the flaps, spoilers and dump valves are set correctly. |
The big Kestrel is a pain to rig. Fortunately it happens relatively
seldom. Somehow it never seems to just come together. That said, the tight fit means that even after 30+ years there is no play at the wingtips, and she feels rosk solid. YOu just have to have very good friends if you want help rigging. On 2014-07-22 06:37, Tim Taylor wrote: I found with the Ventus and Nimbus it is good to clean the pins on the end of each spar root and wing root should be cleaned with 00 steel wool every few years and then lubed carefully. The spherical bearings on the fuselage and on the wing roots should be cleaned until they move freely. They can be rotated and removed if installed correctly (incorrectly and they go into the tubes). Q-tips and solvent will help free then up. I have found many ships have never been cleaned in years. Usually the tightness for the last 1/4 to 1/2 inch are from lack of cleaning as long as the flaps, spoilers and dump valves are set correctly. -- Bruce Greeff T59D #1771 |
I find my Discus 2 can be a dog to get the last inch of the wings in on a hot day (common in Arizona), but much, much easier on a cool day. Presumably thermal expansion plays a role?
The spoilers are what usually hang up, so I give the handle a last tweak to clear them before the final push. The manual says to rig the left wing first, but most owners do it the other way round so they can easily access the cockpit. Otherwise, clean, grease and push! Mike (WA) |
Apart from being heavy I always found my old Kestrel 19 a very
easy rig. You can see and get to the top of the spars so you can see where all the pins should be and there are studs on the top of each spar stub so that you can use the special rigging lever to draw them together. I sold the glider almost 30 years ago but still have the lever. If you have the studs but not the lever let me know Bruce. John Galloway At 04:44 22 July 2014, BruceGreeff wrote: The big Kestrel is a pain to rig. Fortunately it happens relatively seldom. Somehow it never seems to just come together. That said, the tight fit means that even after 30+ years there is no play at the wingtips, and she feels rosk solid. YOu just have to have very good friends if you want help rigging. On 2014-07-22 06:37, Tim Taylor wrote: I found with the Ventus and Nimbus it is good to clean the pins on the end of each spar root and wing root should be cleaned with 00 steel wool every few years and then lubed carefully. The spherical bearings on the fuselage and on the wing roots should be cleaned until they move freely. They can be rotated and removed if installed correctly (incorrectly and they go into the tubes). Q-tips and solvent will help free then up. I have found many ships have never been cleaned in years. Usually the tightness for the last 1/4 to 1/2 inch are from lack of cleaning as long as the flaps, spoilers and dump valves are set correctly. -- Bruce Greeff T59D #1771 |
I don't have my Ventus so I can't measure where the hole is located. The location is not critical however. From the fully locked position, pull the airbrake handle aft so that it is not locked. From this position, pull the handle aft gently to where you just start to feel resistance against the airbrakes. This position is the sweet spot. If you don't have a hole, another option might be to cut a piece of small aluminum angle to the correct length and use this to block the airbrake handle open to this position.
How hard is a Diamant to assemble? | Spam | Soaring | 18 | July 5th 15 02:54 PM |
U2: Big Glider; hard to land | [email protected] | Soaring | 1 | March 16th 09 09:15 AM |
Do you assemble your glider paying good attention to it? | [email protected] | Soaring | 6 | January 24th 07 10:48 AM |
Do you assemble your glider paying good attention to it? | Steve Leonard | Soaring | 0 | January 23rd 07 12:53 AM |
A&P signoff required to re-assemble 1-26? | [email protected] | Soaring | 5 | July 13th 05 05:32 PM |
