Hard to assemble glider
Old July 22nd 14, 05:44 AM posted to rec.aviation.soaring
BruceGreeff
Default Hard to assemble glider
The big Kestrel is a pain to rig. Fortunately it happens relatively
seldom. Somehow it never seems to just come together.
That said, the tight fit means that even after 30+ years there is no
play at the wingtips, and she feels rosk solid. YOu just have to have
very good friends if you want help rigging.
On 2014-07-22 06:37, Tim Taylor wrote:
I found with the Ventus and Nimbus it is good to clean the pins on the end of each spar root and wing root should be cleaned with 00 steel wool every few years and then lubed carefully. The spherical bearings on the fuselage and on the wing roots should be cleaned until they move freely. They can be rotated and removed if installed correctly (incorrectly and they go into the tubes). Q-tips and solvent will help free then up.
I have found many ships have never been cleaned in years.
Usually the tightness for the last 1/4 to 1/2 inch are from lack of cleaning as long as the flaps, spoilers and dump valves are set correctly.
Bruce Greeff
T59D #1771
Old July 22nd 14, 05:04 PM posted to rec.aviation.soaring
Mike the Strike
I find my Discus 2 can be a dog to get the last inch of the wings in on a hot day (common in Arizona), but much, much easier on a cool day. Presumably thermal expansion plays a role?
The spoilers are what usually hang up, so I give the handle a last tweak to clear them before the final push. The manual says to rig the left wing first, but most owners do it the other way round so they can easily access the cockpit. Otherwise, clean, grease and push!
Mike (WA)
Old July 22nd 14, 05:34 PM posted to rec.aviation.soaring
John Galloway[_1_]
Apart from being heavy I always found my old Kestrel 19 a very
easy rig. You can see and get to the top of the spars so you
can see where all the pins should be and there are studs on the
top of each spar stub so that you can use the special rigging
lever to draw them together. I sold the glider almost 30 years
ago but still have the lever. If you have the studs but not the
lever let me know Bruce.
John Galloway
relatively
is no
to have
pins on the
00 steel wool
bearings on the
move freely.
(incorrectly and
up.
lack of
set correctly.
Bruce Greeff
T59D #1771
How hard is a Diamant to assemble? Spam Soaring 18 July 5th 15 02:54 PM
U2: Big Glider; hard to land [email protected] Soaring 1 March 16th 09 09:15 AM
Do you assemble your glider paying good attention to it? [email protected] Soaring 6 January 24th 07 10:48 AM
Do you assemble your glider paying good attention to it? Steve Leonard Soaring 0 January 23rd 07 12:53 AM
A&P signoff required to re-assemble 1-26? [email protected] Soaring 5 July 13th 05 05:32 PM
