Hard to assemble glider
Old July 23rd 14, 01:14 AM posted to rec.aviation.soaring
Default Hard to assemble glider
Dennis,
The pin is @ 10" long and @ 3/16" dia with one end turned down to a reduced diameter that fits the hole in the inner sleeve of the airbrake as well as the water caps. The length helps insure that you don't inadvertently leave it in the hole as it crosses much of the instrument panel when inserted. This pin and the alignment pin that helps bring the wings in the last 1/2" should have come with the glider. My trailer has a dedicated place for these tools inside on the left rear rail.
How hard is a Diamant to assemble? Spam Soaring 18 July 5th 15 02:54 PM
U2: Big Glider; hard to land [email protected] Soaring 1 March 16th 09 09:15 AM
Do you assemble your glider paying good attention to it? [email protected] Soaring 6 January 24th 07 10:48 AM
Do you assemble your glider paying good attention to it? Steve Leonard Soaring 0 January 23rd 07 12:53 AM
A&P signoff required to re-assemble 1-26? [email protected] Soaring 5 July 13th 05 05:32 PM
