Noise issues with Oudie 2 in a couple different aircraft
Old July 25th 14, 02:22 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Noise issues with Oudie 2 in a couple different aircraft
I have found it useful to turn off the automatic squelch, then turn on all your equipment, one at a time. The squelch background noise will rise with any offending unit. The Cambridge model-20 and ILEC SN-10 both add significant background noise, so do some of the power supplies for additional units.. Remember the radio is doing exactly what it was designed to do, It thinks a weak signal is bing received and sends that 'weak signal' to the speaker. I have found that moving offending equipment away from the radio and its antenna have solved the problem. Have patience, you'll need it!
JJ
Oudie Issues vontresc Soaring 4 July 16th 14 04:44 AM
Why bother about light aircraft noise. [email protected] Piloting 36 July 13th 05 09:52 PM
Newer aircraft mx issues SAC Owning 4 July 6th 05 05:59 PM
Couple of Plugs: Stan Shannon and Wicks Aircraft Larry Smith Home Built 8 November 8th 03 01:22 AM
ISO back issues Combat Aircraft magazine mark e digby Military Aviation 0 August 12th 03 05:39 PM
