Glider pilot rolls inverted and exits at 1400 feet AGL
Old August 2nd 14, 03:21 PM posted to rec.aviation.soaring
Default Glider pilot rolls inverted and exits at 1400 feet AGL
I notice that he did not jettison his canopy, just opened it.
In the first frame you can see it still attached.
Still worked out ok.
  #42
Old August 2nd 14, 04:14 PM posted to rec.aviation.soaring
Dave Nadler
Still worked out ok...
Please be sure you understand the bailout sequence for
any aircraft you fly. For SH gliders (as this appears
to be), jettisoning the (non-Roget-hook-equipped) canopy
can result in the canopy swinging sideways and hitting
you in the head and incapacitating you, or merely
breaking your jaw as happened to a friend of mine.
Consequently, IIRC the procedure was changed to open
only and do NOT pull the jettison knob.
Please be safe out there and MAKE SURE you know
your jettison procedure! Then periodically practice
on the ground...
Best Regards, Dave
  #44
Old August 2nd 14, 05:21 PM posted to rec.aviation.soaring
Craig Funston
on the ground...
Best Regards, Dave
Dave,
I'm curious about your comment regarding changes in recommended bailout procedures for SH type sailplanes. I don't find any reference to not jettisoning the canopy on the SH website and there are no listed changes to the Nimbus 3 flight manual. The FM recommends first opening the left side and then raising the canopy and pulling the hinge pins. This is the way I practice it, however, honestly I've never been convinced the canopy would really go away. Front release and a Roeger hook has always seemed like a better solution.
Glad to see that the UK pilot got away safely regardless of how it was accomplished.
Thanks,
Craig 7Q
  #46
Old August 2nd 14, 06:35 PM posted to rec.aviation.soaring
John Galloway[_1_]
recommended bailout
pro=
not
jettison=
changes to the
Nim=
side and
then=
way I
practice=
would really
go=
like a better
sol=
ution.
how it was
acco=
mplished.
Thanks,
Craig 7Q
I can't speak for the Nimbus 3 but for more modern SH gliders
to jettison the canopy you open the canopy with the left side
handle as usual and the right side hinges and canopy position
cord are designed to tear away. The black right side canopy
removal knob is only for removal for maintenance etc (and for
confusing with the nearby fuel valve in turbos - especially when
the canopy is open on the ground).
I found that good ways to accidentally practice (almost)
jettisoning modern SH canopies are to catch the left side
opening handle in the cuff of a long sleeve shirt or in a glove.
John Galloway
  #47
Old August 2nd 14, 06:51 PM posted to rec.aviation.soaring
Dave Nadler
Hi Craig - My original Ventus B manual had same recommendation a
your manual. IIRC the Duo manual has the newer procedure (but I
sold that glider a couple years ago - don't have a manual handy
to check). I really don't know about flight manual updates for
older SH gliders.
Best to contact your SH dealer!
Hope that helps,
Best Regards, Dave
PS: You'll remember Roy had his jaw wired shut for a while until
the bones healed; we sent him a pizza ;-)
  #48
Old August 2nd 14, 09:56 PM posted to rec.aviation.soaring
waremark
You seem to be able to see the canopy frame attached, but you can see
the canopy itself up to the left of the tailplane.
Agreed. It looks to me as if the frame stayed attached to the fuselage
while the plastic blew out. The latter is quite hard to see and has at
most some paint round its edges.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
When I had my midair the canopy broke away from the frame in the impact leaving the frame in place - and it was still in place later on in the wreckage. The pilot in the other glider, an ASW 27 which has a front hinged cockpit, used the normal canopy release, and had to squeeze himself out against wind pressure between the edge of the cockpit and the canopy. The whole canopy was still attached to the wreckage afterwards. He was surprised to discover this - he thought he had used the red emergency jettison levers, which are ahead of the white canopy release levers in Schleicher gliders. It must have been much more difficult for him to get out (but happily like me he was unhurt). There is a moral there - regularly practice your bail out routine.
  #49
Old August 3rd 14, 08:49 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Has anybody bailed out from a Libelle or knows anybody who has? I'm just
wondering if the two rear pins act as a pseudo Roeger Hook and/or if you
need to guard against the canopy clobbering your head as it departs
org |
  #50
Old August 3rd 14, 09:29 PM posted to rec.aviation.soaring
Craig Funston
older SH gliders.
Hope that helps,
Best Regards, Dave
Thanks Dave,
The Duo and Arcus have massive expanses of plexi and trying to jettison them definitely seems problematic. I'll dig into it a bit further for the Nimbus.
Best regards,
Craig
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
JetPilot and Team Payne win USA OLC with Brilliant Last Minute 1400 km Wave Sortie [email protected] Soaring 1 October 12th 07 05:28 AM
Youth lands glider after dad blacks out at 3,000 feet [email protected] Soaring 0 July 27th 06 12:40 AM
New style emergency exits Michelle Piloting 7 February 7th 06 10:45 PM
5000th glider rolls out the SZD factory Janusz Kesik Soaring 0 November 19th 04 07:29 AM
