World Championship gliders
Old August 6th 14, 10:31 PM posted to rec.aviation.soaring
Sean Fidler
Default World Championship gliders
I agree the 15/18 meter thing is going well, for now. No glider in these classes has a clear advantage (perhaps the Diana 2 but the company is a mess....) but only a certain subset of gliders are competitive in each class. If you don't have a 27, V2 in 15m (http://www.wgc2014.hb.pl/wyniki/15m/486_15m.htm) or a 29, V2 or JS1 in 18m (http://www.wgc2014.hb.pl/wyniki/18m/486_18m.htm), good luck! This has been the case for 10 years or so. But for how much longer will that last?
If a new glider comes along that is a "game changer" in either class (only a matter of time) the delicate balance that we currently enjoy would likely collapse pretty quickly. And hundreds of gliders that are today competitive will become basically obsolete.
Imagine if the Duckhawk had turned out to be "unbeatable" or clearly better in 15m and 20 US guys/gals ordered them. Imagine if 1st-8th at the US 15m nationals was composed of Duckhawks (every year), then a mix of 27s and V2's, etc. For how long would the Nationals attract 27s and D2s? Sure, a few would upgrade their gliders to the new performance level but many would simply no longer attend.
In 18m (and 15m as well), the rumored Ventus 3 approaches perhaps as early next year. Deposits are already flying into the US dealers hands. Why? Because pilots all want to buy a competitive advantage. This is part of the game in soaring today. If the V3 turns out to be dominant (its design goal!) then the V2's, 29's etc all the sudden scramble for the new performance level. But a certain number will simply give up on the Nationals.
If a designer/builder "nails it" and designs/builds a game changing glider....all bets are off. The risk is that the 15/18 meter classes get destroyed and not enough new buyers are willing to spend the money to "be competitive." A net loss initially that may never recover.
In the US, our already delicate Nationals scene would be severely disputed by such a glider. The SSA response would likely need to be handicapping. Etc, etc. A whole new set of problems there.
The PW5 was WAY too low of a performance level for One Design to work. If a glider of the 45:1 or greater performance was available at a reasonable price, a builder could get tremendous buy in for a one design class at all levels (Nationals and World level). One Design is a completely different mindset than trying to leapfrog other builders performance level. In leapfrogging, a builder gets a surge of sales and then a steep taper. In One Design the builder gets a gradual build in sales after an initial commitment from perhaps 50-100 buyers, then a steady track of sales over 20-30 years or more.
I for one would be very interested and supportive of a mid/high performance One Design glider concept being offered by a builder.
One Design is also less about the builder and more about developing a large consortium of like minded pilots. A group of pilots who are thinking long term.
Imagine is the ASW27 or LS8 or D2, etc was introduced as a one design class.. Or look at it this way. The Olympics does not even allow different builders of their One Design boats. All boats are built in the same run, etc. Soaring could learn a thing or two from sailing I think.
Sean
Old August 6th 14, 11:00 PM posted to rec.aviation.soaring
jfitch
On Wednesday, August 6, 2014 2:31:34 PM UTC-7, Sean Fidler wrote:
I agree the 15/18 meter thing is going well, for now. No glider in these classes has a clear advantage (perhaps the Diana 2 but the company is a mess...) but only a certain subset of gliders are competitive in each class. If you don't have a 27, V2 in 15m (http://www.wgc2014.hb.pl/wyniki/15m/486_15m.htm) or a 29, V2 or JS1 in 18m (http://www.wgc2014.hb.pl/wyniki/18m/486_18m.htm), good luck! This has been the case for 10 years or so. But for how much longer will that last?
If a designer/builder "nails it" and designs/builds a game changing glider...all bets are off. The risk is that the 15/18 meter classes get destroyed and not enough new buyers are willing to spend the money to "be competitive." A net loss initially that may never recover.
Imagine is the ASW27 or LS8 or D2, etc was introduced as a one design class. Or look at it this way. The Olympics does not even allow different builders of their One Design boats. All boats are built in the same run, etc.. Soaring could learn a thing or two from sailing I think.
Sean
Of course a massive shift to a one design glider costs the same to the participants as a massive shift to a new competitive glider.
Even in one design yacht racing, some boats seem to be faster than others whether is it newer sails, a 3 sigma light hull, or whatever. That's why the fairest racing is done in collegiate, where in many regattas crews rotate boats every race of the series. Bringing a "hot" or tweaked boat then gives you no advantage. Somehow I don't see that being agreed to in soaring....
Old August 6th 14, 11:06 PM posted to rec.aviation.soaring
Tony[_5_]
I agree the 15/18 meter thing is going well, for now. No glider in these classes has a clear advantage (perhaps the Diana 2 but the company is a mess...) but only a certain subset of gliders are competitive in each class.. If you don't have a 27, V2 in 15m (http://www.wgc2014.hb.pl/wyniki/15m/486_15m.htm) or a 29, V2 or JS1 in 18m (http://www.wgc2014.hb.pl/wyniki/18m/486_18m.htm), good luck! This has been the case for 10 years or so. But for how much longer will that last?
Imagine is the ASW27 or LS8 or D2, etc was introduced as a one design class. Or look at it this way. The Olympics does not even allow different builders of their One Design boats. All boats are built in the same run, etc. Soaring could learn a thing or two from sailing I think.
Sean
Even in one design yacht racing, some boats seem to be faster than others whether is it newer sails, a 3 sigma light hull, or whatever. That's why the fairest racing is done in collegiate, where in many regattas crews rotate boats every race of the series. Bringing a "hot" or tweaked boat then gives you no advantage. Somehow I don't see that being agreed to in soaring.....
maybe we need to adopt a claim rule like the hometown dirt track does with IMCA hobby stocks and the like. If we think you've been tweaking a bit too much on your (insert glider here), I get to buy it!
Old August 7th 14, 01:45 AM posted to rec.aviation.soaring
Sean Fidler
True but your one design glider would be competitive for many years. Currently your looking at 5-10 years before it becomes obsolete.
Old August 7th 14, 09:02 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
That may well prove to be the case but the Ventus 2 first won a worlds in 1995 (15m) and still figures prominently even today. There have been incremental improvements for sure but it's fundamentally the same glider.
Colin
Old August 7th 14, 03:25 PM posted to rec.aviation.soaring
Sean Fidler
I stand corrected. 10-20 years. Impressive that the V2 has been competitive for so long. Regardless of specific competitive lifespan of each design, at current its only a matter of time before each design gets leapfrogged (and made obsolete in 15/18 or even standard). If the strength of the economy or popularity of the sport improves (often linked) under the current model, the pace of new designs leapfrogging eachother would increase significantly.
Do we really need a new 15 meter glider with 1-2% more performance (Duckhawk goal)? Do we really need a new 18 meter glider with 1-2% more performance which makes everything else on the market basically obsolete (Ventus 3)? Perhaps the leap in performance could be even more than 2%?
I am happy buying a new 29 or V2, ESPECIALLY IF I knew that it was going to be competitive for a long period in the future. But right now, buying a new 29 or V2 is unwise until we know what the Ventus 3 is capable of doing.... I actually wanted to buy a new glider at the beginning of this season and passed.
This current marketplace and international organization mindset in the sport of soaring is very interesting...
The only fact is that the sport is slowly shrinking, new glider sales are slowing and new glider prices are rapidly increasing. Hmmm, where have I seen this before?
Sean
glider.
Colin
Ventus_a
Old August 8th 14, 02:35 AM posted to rec.aviation.soaring
waremark
Sean said: 'new glider sales are slowing'.
Is that true? Schleicher and S-H seem to be operating at capacity (I was quoted 3 years delivery on an Arcus, so bought a pre-owned one) and they are bringing out new models thick and fast. And as mentioned in the Shark thread, there is an unusually wide range of choice of high performance rivals from other manufacturers - Lak, Shark, JS1, Binder, Antares, and DG come to mind. Most of them seem to have full order books. Then there are the new generation of lighter gliders such as Silent, Pipistrel and Phoenix.
These gliders are not only being bought because the buyers all expect to win world championships with them.
If you want to fly a lower performance cheaper class, what is wrong with the Club class?
Old August 8th 14, 04:15 AM posted to rec.aviation.soaring
Sean Fidler
Club class is very good, but it is based on handicap racing and (mainly) very old glider designs. The handicap range is fairly wide. Also, certain gliders become more competitive/less competitive based on the conditions. I know of several pilots that had "weak weather gliders" and "strong weather gliders." I find this annoying.
I agree there is little chance of a one design glider class coming to fruition. The current manufacturer driven climate in the sport is fairly locked in for now. They are good people and design and build great products. But I stand behind the idea that a one design concept could improve their business model and the enjoyment of racing pilots in the future. I believe a one design class could strengthen the sport of soaring.
Perhaps organizing a one design class from an existing glider which has been built in large numbers (ASW-20 for example) could be successful. The only problem is that Schleicher is not going to build new ASW20's. I would have more fun flying against 30 almost identical gliders then flying in a handicap class (or maybe even the "rule" class of 15 or 18 meter). Imagine the ASW20 Nationals. Or the ASW20 Worlds? For your SH folks, the D2 Nationals or Worlds.
Oh well, one can dream. Its pretty clear that few here are receptive to the idea of a mid-high performance one design glider at this time. At least I have plenty of One Design sailing to enjoy.
Sean
Old August 7th 14, 09:15 PM posted to rec.aviation.soaring
Paul T[_4_]
Discus 2a/LS8 - getting on for 20 year old designs now - well the 8 is
even older considering its essentialy an unflapped 6.
Paul T[_4_]
No Love for the Uvalde 2012 World Championship? Scott Alexander[_2_] Soaring 4 February 7th 12 01:50 AM
FAI World GP Gliding Championship - Starts Soon! Peter Newport Soaring 2 December 15th 07 02:22 AM
1965 World Championship Steve Leonard Soaring 1 September 17th 07 07:43 AM
1965 World Championship Michael Corcoran Soaring 2 September 17th 07 07:38 AM
World Aerobatic Championship Videos/DVDs??? [email protected] Aerobatics 0 August 19th 05 01:21 AM
