Another mid-air (UK)
Old August 7th 14, 05:06 PM posted to rec.aviation.soaring
son_of_flubber
Default Another mid-air (UK)
On Thursday, August 7, 2014 11:46:30 AM UTC-4, Ramy wrote:
Even with 8m accuracy, It is more than sufficient for accurate collision avoidance, unless someone considers half a wingspan not accurate enough for collision warning with another glider or obstacle.
Prompted to comment here by my Geek Fascination Syndrome (GFS)...
I'd guess that the error on each position fix is not significant. Flarm is computing trajectories from multiple position fixes, so a maximum +/- 8M error for each fix will be smoothed out by the statistical distribution of a large number of position fix errors. Some of the errors are + and some are -. Average 100 GPS position fixes and you will get a pretty accurate position.
I'd expect that the sampling rate is high enough to make the trajectory calculations quite accurate. If the sampling rate was not fast enough they could put a faster processor into the units. Plus as Ramy pointed out, FLARM must be alerting for 'possible near misses' because there will be small deviations in trajectory caused by turbulence and pilot control inputs.
The 8M 'error' of GPS is unlikely to be the critical factor that keeps FLARM from fulfilling its mission. I'd bet that the critical factor is the human pilot, that being the most inherently error prone and undependable part of the system.
Old August 7th 14, 05:55 PM posted to rec.aviation.soaring
Stats Watcher
accurate
collision=
accurate enough
fo=
r collision warning with another glider or obstacle.=20
(GFS)...
Flarm is
maximum +/- 8M
er=
distribution of a
and some are
accurate
positi=
on.
trajectory
cal=
enough they
co=
out,
FLARM=
be small
de=
inputs.
keeps
FLAR=
hum=
undependable part
of the system.
+-8m 95% of the time is best case, under ideal conditions and
installations. Do you fly only in ideal conditions and have an
ideal installation? f the answer is 'no' your error will be larger.
Also this is 2D error. As everyone 'knows' and goes on ad-
nauseam, GPS vertical error is significantly worse.
Have you 'any' evidence for the rest of your post or is it just
pure supposition? If you analyse the data rate and bandwidth
requirements of the data link you'll realise what you suggest is
impossible
Old August 7th 14, 07:09 PM posted to rec.aviation.soaring
JS
Whether or not any of this has a thing to do with the original post:
The technology discussed is not perfect, and like a vario is supplementary.
Is your scan 100% perfect? Are your eyes? After 8 hours of flying? Burning from sweat and sunscreen?
Will your vision improve with age? Will you admit it?
Old August 7th 14, 08:12 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Op donderdag 7 augustus 2014 18:55:16 UTC+2 schreef Stats Watcher:
Error is cumulative, that's how d-GPS and WAAS work. So the guy a mile away from you also has 8 or more meters of error. In exactly the same direction vector as for you. So relative accuracy is virtually +/-0...
Old August 7th 14, 10:02 PM posted to rec.aviation.soaring
son_of_flubber
impossible
The error correcting computations that I suggest consume ZERO communication bandwidth between FLARM units. The only thing that needs to be broadcast over the data link is the trajectory vector.
Old August 7th 14, 08:24 PM posted to rec.aviation.soaring
Alan[_6_]
In article son_of_flubber writes:
Even with 8m accuracy, It is more than sufficient for accurate collision=
avoidance, unless someone considers half a wingspan not accurate enough fo=
I'd guess that the error on each position fix is not significant. Flarm is =
computing trajectories from multiple position fixes, so a maximum +/- 8M er=
ror for each fix will be smoothed out by the statistical distribution of a =
large number of position fix errors. Some of the errors are + and some are =
-. Average 100 GPS position fixes and you will get a pretty accurate positi=
on.
Not so much as you might expect. The error varies more slowly over
time. If those 100 fixes were taken one every hour or two, then they
would average out much better than fixes taken once per second.
The fact that the error moves more slowly helps the trajectory calculation
as successive samples will have a similar error.
Alan
