Pawnee 235 vs Cessna Bird Dog vs Maule as towplanes
Old August 21st 14, 05:36 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Pawnee 235 vs Cessna Bird Dog vs Maule as towplanes
On Thursday, August 21, 2014 11:18:10 AM UTC-5, Mike the Strike wrote:
Don't exclude the Cessna 175 from consideration. Mike
Only if is has at least the 180HP conversion with C/S prop. Or better yet, the 0-470 conversion (230 HP) with C/S Prop. The only real issue with the latter is the CG tends to be very far fowrard, and you can not use more than 2 of the 4 notches of flap for landing, or you will not have enough elevator power to slow down and the nose gear will be the first thing to contact the ground. Not a good way to land those things!
Have no data to help out relative to the others. My club operates a 182 and a 175 with the 0-470 conversion. Both are good at pulling gliders up even with the spoilers out.
Old August 21st 14, 06:41 PM posted to rec.aviation.soaring
kirk.stant
Our field is all grass so we prefer taildraggers; in fact, all of the power planes on our field (2 club towplanes and 3 private planes) are taildraggers.
We're thinking of charging a landing fee for nosedraggers... ;^)
Kirk
66
Old August 21st 14, 07:04 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, August 21, 2014 12:41:29 PM UTC-5, kirk.stant wrote:
We're thinking of charging a landing fee for nosedraggers... ;^) Kirk 66
As a friend of mine once said, "Tail-dragger pilot break ground and head into the wind. Nose-dragger pilot break wind and head into the ground!" Good enough to put on a tee shirt?
Steve
Old August 22nd 14, 12:02 AM posted to rec.aviation.soaring
son_of_flubber
Not the rile the conservative feathers of the tow plane experts, but I wonder if anyone in the USA has a scenario where a combination tow plane motor-glider trainer like the Phoenix makes sense? http://www.phoenixairusa.com/Specifications.php
I believe it has a bigger engine option if you need the pull for towing.
I wonder how it compares to the traditional big iron choices if you fairly consider all of the variables. Would it make sense if a club used it as a backup tow plane and otherwise used it for training (including XC training!). You might get some income from renting it by the hour. It might make sense for a private hobby-commercial glider port in a remote area with few customers and an owner with other reasons for owning a commuter plane.
Old August 22nd 14, 01:02 AM posted to rec.aviation.soaring
Dan Marotta
I've towed with all three plus the Ag Wagon, CallAir, 180 Super Cub, and
180 Citabria.
I think the Ag Wagon is the best of what I've used and it uses by far
the most gas, but of the three requested, I'd choose the Pawnee. It's
simple to fly, tows well, and it's very basic so maintenance won't be as
much. The CallAir is extremely heavy on the controls and will wear you
out, but it is also the easiest to land tail dragger I've ever flown
(except for the Stearman). The Maule was no fun at all as a tow plane.
The Bird Dog was a lot of fun but maintenance will be higher.
Dan Marotta
Old August 22nd 14, 03:31 AM posted to rec.aviation.soaring
Bill D
This makes a lot of sense. The far better aerodynamics and lower weight of a touring motor glider airframe makes up for about half the HP of a Pawnee.
Interestingly, a group of pilots visiting the 15m/Open Nationals at Montague told a story they were testing a higher HP version of the ROTAX - they said as much as 140HP. That would make the Phoenix a dandy tug.
Temora last Sunday - Cessna Bird Dog. Darryl Gibbs Aviation Photos 0 April 28th 08 09:31 AM
My Dad's Temora pics : Cessna O-1G 'Bird dog' Dave Kearton Aviation Photos 0 March 30th 07 10:16 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
