If it is a metal top from before 1990 no dice on keys from Cobra...they are right for later trailers though. From what you describe I do not think that keys would help anyway. Install a hasp as you mentioned and Mark suggests.
Locking the front door for long trips is a good idea.
I've epoxy'd a piece of wood (paint stirring stick) in a couple of trailers as a speed bump for the latch to go over before it will unlock. Give that a try? Jim On Tuesday, September 9, 2014 7:25:56 AM UTC-7, MQ wrote: If it is a metal top from before 1990 no dice on keys from Cobra...they are right for later trailers though. From what you describe I do not think that keys would help anyway. Install a hasp as you mentioned and Mark suggests. |
On Tuesday, September 9, 2014 3:03:35 PM UTC-4, JS wrote:
Locking the front door for long trips is a good idea. I've epoxy'd a piece of wood (paint stirring stick) in a couple of trailers as a speed bump for the latch to go over before it will unlock. Give that a try? Jim On Tuesday, September 9, 2014 7:25:56 AM UTC-7, MQ wrote: If it is a metal top from before 1990 no dice on keys from Cobra...they are right for later trailers though. From what you describe I do not think that keys would help anyway. Install a hasp as you mentioned and Mark suggests. I have problems more with the back door on long trips ('80s fiberglass top). I've taken to running a strap between the latches for the top to keep the door closed. The lock will work itself out even with the strap over it! Matt |
Cobra Trailer-Replacing front panel | K | Soaring | 2 | January 15th 14 02:25 PM |
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
Cobra Trailer leak, front end gasket, fix? | SF | Soaring | 1 | December 20th 10 07:30 PM |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
[1/1] - 01 Starboard Forward access door.JPG (1/1) Part 2 - Main event Spruce Goose. | Waldo.Pepper[_2_] | Aviation Photos | 0 | September 10th 08 11:22 PM |
