Where is the LX S80?
Old September 19th 14, 10:11 PM posted to rec.aviation.soaring
Default Where is the LX S80?
Looks like a direct competitor to the Butterfly vario.
I wonder if it will have a similar vertical airmass indicator based on inertial reference that essentially eliminates horizontal gust induced energy changes like the Butterfly vario does. I am hoping there will be a dedicated indicator for this reading that can be directly compared to the "regular" vario indicator to help determine if that lift indication is due to a horizontal gust or not.
The specs make no mention of a magnetometer, only a gyro based system. Curious how this effects instantaneous wind calculations.
Old September 19th 14, 10:18 PM posted to rec.aviation.soaring
A careful reading of the literature on the S80 shows that a magnetic compass module is needed for instantaneous winds.
Old September 19th 14, 11:21 PM posted to rec.aviation.soaring
jfitch
That kind of suggests that the wind is really calculated from GPS/TAS/Heading, doesn't it?
On the Butterfly, wind is inertially derived and truly instantaneous - like 20 times per second. If you use iGlide you can see this in the thermal assistant: every second there is a proportional lift dot, in each lift dot is an instantaneous wind direction arrow, and (at least in nicely organized thermals) these point towards the center of the thermal.
