![]() I can't really help with this, other than to wonder if lend-lease allocations might be responsible, in terms of aircraft delivered against USAAF All air force Lend-Lease aircraft were first taken into the air force, so should be included in USAAF deliveries. This extended even to aircraft the USAAF never adopted, notably the Vultee P-66s that show on the air force books. They went straight to China, or rather India. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
On Wed, 12 May 2004 05:10:57 -0400, Cub Driver
wrote: All air force Lend-Lease aircraft were first taken into the air force, so should be included in USAAF deliveries. What do you mean by "taken in", though? All lend-lease aircraft were ordered against USAAF or USN contracts, and were allocated US service ID numbers. This does not mean they were ever taken on strength by the US services, however. Most lend-lease Kittyhawks were shipped direct from the factory to the port where they were exported, with little beyond paper records (and the relevant allocated US serial being sprayed on the airframe) recording their production against US procurement contracts. This extended even to aircraft the USAAF never adopted, notably the Vultee P-66s that show on the air force books. They went straight to China, or rather India. Sure, but this is why I asked about the provenance of the figures involved, e.g. for for production totals as calculated by the manufacturer, or delivery totals to the USAAF (i.e. actually received by the USAAF as the end-user). While the P-40s in question were all "USAAF aircraft", some were never formally in the hands of a USAAF unit of any kind. Gavin Bailey -- Now see message: "Boot sector corrupt. System halted. All data lost." Spend thousands of dollar on top grade windows system. Result better than expected. What your problem? - Bart Kwan En |
![]() While the P-40s in question were all "USAAF aircraft", some were never formally in the hands of a USAAF unit of any kind. Oh, certainly. But when you look at USAAF procurement, as in Fahey's "Gray Book", the lend-lease aircraft are there. As I recall, the P-66s are there, for example. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
This will probably appear in the wrong place thanks to a buggy news server.
Presidente Alcazar wrote in message ... On Wed, 12 May 2004 15:35:02 +1000, "Geoffrey Sinclair" wrote: The big difference is the P-40 production June to August 1942, Dean says 560 the Digest says 1,158. As a result mainly of this Dean's P-40 production grand total is around 600 less than other references at 13,143, versus 13,738 in the digest for example. Are these figures for production totals as calculated by the manufacturer, or delivery totals to the USAAF? The USAAF statistical digest uses the definition factory acceptances which I understand means when the aircraft has been certified as being of acceptable quality, as opposed to just pushed out the factory door (usually called manufactured), or arriving at the relevant new military aircraft depot (usually called delivered). The above definition is for tables 74 (all military by basic types and month), 75 (by factory by year) and 76 (USAAF aircraft only, by model by month). Table 79 is factory deliveries, not acceptances, by recipient country by month by basic type (e.g fighters). As a result the totals in table 79 are different to the other tables, since it is measuring production at a different point. Dean and the Digest match each other very well except for those few months of P-39 and P-40 production. Other references I have tried support the digest. So it appears Dean is incorrect. I will put the differences back up, P-40, until June 1942 the figures are close to identical (difference of 2 in January 1941, 1 in May 1942, out of around 4,770 built to end May 1942). Then comes the upheaval, table is date, Dean, Digest, 6/42 / 282 / 347 7/42 / 135 / 421 8/42 / 143 / 390 Totals / 560 / 1158 I can't really help with this, other than to wonder if lend-lease allocations might be responsible, in terms of aircraft delivered against USAAF contracts being exported before being included in USAAF delivery statistics. Even if that was the case, I don't know why allocations should suddenly alter the totals in that period alone if earlier lend-lease allocations (e.g. for the 400-plus P-40E's delivered as Kittyhawk IA's to the British in early 1942) were recorded in the statistics accurately. Lend Lease aircraft all went through the US military procurement system and were given relevant AAF/Navy serial numbers before being sent to an ally. Using Dean's chronology the K model was being produced in May 1942, the long fuselage version in October 1942, the M model began appearing in November 1942. In 1942, using the Digest's table 79, the fighters delivered total was 10,721, of which 5,213 were for the USAAF, 1,259 for the USN, 2,397 for the British Empire, 1,136 for the USSR, 11 for China and 56 for other foreign governments. So it is possible the P-39 and P-40 shipments for a small time period were not recorded in the document's Dean uses. In the three months June to August 1942 the British were allocated 537 fighters, the USSR 340. Remembering the production figures are factory acceptances, the allocations are factory deliveries, so they are not measuring the same thing. In June the difference between Dean and the Digest is 65, the Digest says 103 fighters to the British and 168 to the USSR. In July the difference is 286, the digest says the British received 279 fighters and the USSR 64. In August the difference is 247 and the digest says the British received 155 and the USSR 108 fighters, total 263. So yes the numbers superficially look like somehow Dean's source eliminates Lend Lease aircraft, but of course not all Lend Lease types were P-40s. The British were mainly receiving P-40s but also F4Fs, the USSR was receiving most of the P-39 exports. Having said that, the British only got about 272 Kittyhawks in total between the beginning of June and the end of August 1942, with a further 36 or so from their allocations going to Australia and New Zealand. Diversions to Canada from British Kittyhawk allocations seem to have dried up by then. Equally, none of the British allocation went to Russia at that point (although 170 of their allocation of P-40M's did in 1943). The point here would be the British figures would quite probably be when the aircraft arrived in theatre, an ocean voyage from the factory in the US. I don't know about US Kittyhawk allocations (e.g. lend-lease diversions to Russia from USAAF allocations had been delivered and taken on charge by the USAAF, as opposed to being delivered direct from the factory as in the case of British lend-lease allocations) , but the British allocations seem to account for less than 50% of your total discrepancy, so the issue of lend-lease allocation seems less than credible. On the other hand, procurement contract discrepancies might account for it. Production of the F and K models should account for deliveries in June - August 1942. I think 600 P-40F's were ear-marked for an "R" designation for training. While that total would match your total discrepancy, they should still be recorded against P40 deliveries to USAAF contracts, especially as I don't know if any were actually re-designated in the event. That is another possibility, the systematic exclusion of a given model for a particular reason. The trouble with this as an explanation is the P-39 figures, where Dean ends up with a larger total than the Digest P-39, until July 1942 the figures are close to identical (difference of 1 in April 1942 out of around 1,425 built to end April 1942). Then comes the upheaval, table is date, Dean, Digest, 7/42 / 255 / 170 8/42 / 309 / 60 9/42 / 0 / 132 10/42 / 3 / 145 11/42 / 268 / 277 Totals / 835 / 784 So if the problem is P-40s being missed because of systematic error in counting Lend Lease or a given model something else is happening for the P-39. The first P-39 K and Ls were delivered in July 1942, the P-39D-2 for the RAF began deliveries in June 1942. The similarities in the problems in the P-39 and P-40 figures are the overlap in the time frame, the fact both had only one production line, with both plants being in Buffalo NY. It is not like I can see the numbers being put in the wrong columns or add the different monthly totals and end up in agreement. The P-40K's being produced at the same time had a similarly suggestive number total associated with their procurement. While more than a thousand K's were made, originally 600 of these were on order for China (taken over by the USAAF after Pearl Harbor) and about 190 of that total were diverted to the British to repay them for the 100 Tomahawks they'd had diverted to the AVG in 1941. Perhaps this ex-Chinese order was complicating the paperwork; aircraft from this order seem to be being delivered to the RAF for delivery to the Middle East in August or September 1942 (where they turned up in operational squadrons a couple of months later). Again, however, the same problem arises in that these aircraft were still produced for and delivered against existing USAAF contracts, and should be counted in both production and service delivery statistics in either of your sources. To continue on the 600-aircraft theme, I think 600 P-40M's were made, and only for delivery via lend-lease (i.e. with no USAAF use) which would tie in with your total discrepancy better than the F's (more than that were delivered), but they only started production in August (IIRC), so I can't see them causing such a major discrepancy in the July-August delivery statistics. The K had been in scale production for a couple of months before the start of the period in question, so it seems a much more likely candidate. None of this, of course, answers your question. Sorry. No problems, thanks for the reply. My own personal feeling is that the 50% reduction in statistics for P-40 deliveries in July-September 1942 seems to reflect somebody missing out one or other of the two main variants being produced at that time (the F and K) from the total. I suspect that the K's are the most likely candidate, as the M's coming into scale production by the last quarter and being included in the statisics might re-align them with the USAAF totals if the F's or K's had been missed out for a period. As far as I can tell Dean is incorrect, he is very much concentrating on the engineering of the aircraft and has made an error in the production counts, which were outside his main focus. I totalled up Dean's breakdown of P-40s by model type, it comes to 14,047 versus his table total of 13,143, and the digest's total of 13,738. For the P-39 it is 9,529 in the by model type list, 9,547 in his table and the digest says 9,588. Interestingly the P-38, 47, 51, 61, 63, Buffalo, Wildcat, Hellcat and Corsair breakdowns by model type all are totalled on the page, and the totals agree with the table at the front of the book. The P-39 and P-40 breakdowns by model do not have a total, indicating somebody noticed a problem. I will stick to the digest figures. Geoffrey Sinclair Remove the nb for email. |
On Thu, 13 May 2004 18:02:04 +1000, "Geoffrey Sinclair"
wrote: Dean and the Digest match each other very well except for those few months of P-39 and P-40 production. Other references I have tried support the digest. So it appears Dean is incorrect. That was my assumption: I was merely wondering out loud what systemic error could account for the discrepancy, if any. So yes the numbers superficially look like somehow Dean's source eliminates Lend Lease aircraft, but of course not all Lend Lease types were P-40s. The British were mainly receiving P-40s but also F4Fs, the USSR was receiving most of the P-39 exports. Yes, but many of these came from the British lend-lease allocation - no Airacobras were being exported to the UK by mid-1942. I don't think that should have any impact on the accounting, though. The point here would be the British figures would quite probably be when the aircraft arrived in theatre, an ocean voyage from the factory in the US. In this case I was using British Air Commision records of aircraft exported from the US, which doesn't inlcude diversions elsewhere to other national accounts (e.g. Kittyhawks exported to the Middle East on British account which were then transferred to the French or USAAF in-theatre) or losses en route. At least in the first half of 1942, where I was actually checking individual aircraft deliveries, exports, losses and arrivals in theatre for RAF Kittyhawks in the surviving original records in my research. [snip P-39 production] So if the problem is P-40s being missed because of systematic error in counting Lend Lease or a given model something else is happening for the P-39. It certainly looks like it. I'm less familiar with P-39 production, but I can't account for any type/model designation discrepancies at that time with them, although I could venture some opinions if it involved an earlier chronological opinion. I will stick to the digest figures. Please post an explanation for the discrepancy if you can ever discover one, though. Gavin Bailey -- Now see message: "Boot sector corrupt. System halted. All data lost." Spend thousands of dollar on top grade windows system. Result better than expected. What your problem? - Bart Kwan En |
Message To America's Students: The War, The Draft, Your Future | ~ LITTLE HITLER ~ | Military Aviation | 0 | April 11th 04 11:59 PM |
