alternative McCready theory and variometers
Old October 26th 14, 04:04 PM posted to rec.aviation.soaring
Default alternative McCready theory and variometers
On Sunday, October 26, 2014 8:43:45 AM UTC, Tibor Arpas wrote:
My ideas for features:
* showing equivalentMC http://www.lk8000.it/new-20-features...t-mcready.html
* automatic MC set from equivalent MC
As I understand it, 'Equivalent MC' reverses the STF calculation, and produces a figure from your averaged airspeed and the polar for your aircraft.
For example, assume MC theory for a glider states a STF of 150kph for a 2.0m/s estimated climb. 'Equivalent MC' reverses this equation; If you fly this glider at a constant 150kph IAS for the averaging period, the 'Equivalent MC' will be 2.0m/s.
The way I've heard it described, the idea is that you directly compare your 'Equivalent MC' figure with your MC figure and adjust your airspeed accordingly. If 'Equivalent MC' = 2.1m/s and MC = 2.0m/s, slow down. If 'Equivalent MC' = 1.9m/s and MC = 2.0m/s, speed up.
Climb and sink does not directly influence 'Equivalent MC', which is one reason why 'Equivalent MC' might be a poor value to display on a vario.
Old October 27th 14, 01:09 AM posted to rec.aviation.soaring
pcool
The way eMC works is quite trivial and straightforward for a pilot and it is
well described (by me) in the mentioned web page.
Most people "wish" to fly at - say - MC 1.0, following their stf indicator
on the variometer.
If they fly in sinking air, being downwind a mountain or in a narrow windy
valley, the STF indicator will tell them to fly faster.
A pilot may not be able to balance sink and lift (negative and positive air
zones) during a long glide, for some reasons:
a) weather condition (rain, for example, but also simply a bad zone with
only sinking air)
b) stress and weakness after many hours of flight
c) ignorance - unable to understand what's going on and recover from bad air
Now here is the problem with flight computers: they keep telling you the
arrival altitude based on the MC you have chosen.
Which is a good choice, if you know what you are doing, but only in such
case.
The Equivalent MC is just an automatic MC set by the calculator by looking
to your real average speed.
The arrival altitude will be coherent with what you are doing, not what you
WISH to have done so far.
Then, I know "my chickens": most people do NOT change MC on the PNA,
expecially in bad situations, but most times they do not use it at all on
the PNA.
So how are we supposed to give estimation of arrival altitudes ? Not using a
random MC of course. So we use equivalent MC.
It is important to state that in our software it is possible with a few
clicks to change from manual to automatic MC and there is always an overlay
indicator telling the pilot if the MC is stuck by him or it is dynamically
changing automatically.
Personally I change to manual MC only to understand the possible choices
available, and then back to eMC.
Now it may be worth saying that all the pilots in my area use LK with a
database of mountains, passes, ridges etc.
And in practice we all fly with at least two or three simultaneous
destination - we call them multitargets in the software -: one or more
landing places (in the alps you need to know if you have a place to land
reachable, it is not like in flat lands where you can land anywhere. ), the
task next turnpoint, and the next ridge , next mountain peak, or mountain
pass. So we do constantly look at the arrival altitude over the next ridge
and we can speed up and slow down and look instantly to the estimation.
Then we have a dedicated page to tell us how far we can go and how fast,
making a choice of peaks and ridges around in our direction. But that's not
related to eMC although quite innovative concept .
by the way the flight season this year in the alps has been.. a disaster.
Someone has stolen us the summer.
paolo
aircraft.
Old October 27th 14, 01:24 AM posted to rec.aviation.soaring
Tibor Arpas
For example, assume MC theory for a glider states a STF of 150kph for a 2..0m/s estimated climb. 'Equivalent MC' reverses this equation; If you fly this glider at a constant 150kph IAS for the averaging period, the 'Equivalent MC' will be 2.0m/s.
Yes.
Little clarification: for basic function you don't need to set the MC into the variometer, just keep it in mind.
Little modification: If 'Equivalent MC' shows 2.1 and you expect 2.0 in front of you don't bother slowing down. 0.1 m/s difference is negligible.
I think it's totaly intiuitive to fly fast into good weather and fly slowly into bad weather. This would be just little guidance to learn and later confirm the numbers.
No, I totally would want it to be adjusted for sink and climb.
LK8000 doesn't adjust for that, so it's probably not a good example/definition. What I meant is "flown MC". Its reversing the STF calculation and producing a figure from averaged airspeed, the polar and the rise/sink.
Also as a precaution against a common mistake of flying so slowly in sink that you're actually achieving smaller then maximal achievable L/D I would like to have immediate warning for that (spead up!).
Old October 27th 14, 02:22 AM posted to rec.aviation.soaring
Tom Claffey
Doesn't take long for the boffins to start once macready is mentioned.
Macready works.
What doesn't work so well is the push/pull speed to fly modes of
"smart"varios (and the way Pilots interpret them)
I like Netto in cruise so I can adjust my speed and track accordingly.
I don't require any "speed to fly" function from the electronics. (I seem
to do
OK ignoring them)
Difficult for me to find any instrument that caters for this.
Tom
=20
pro=
aircraft.
=20
2=
fly
t=
'Equivale=
=20
yo=
acco=
rdingly. If 'Equivalent MC' =3D 2.1m/s and MC =3D 2.0m/s, slow down. If
'Eq=
uivalent MC' =3D 1.9m/s and MC =3D 2.0m/s, speed up.
Yes.=20
into
fro=
slowly=
co=
nfirm the numbers.
=20
one
No, I totally would want it to be adjusted for sink and climb.=20
example/definit=
prod=
t=
l=
Old October 27th 14, 02:44 AM posted to rec.aviation.soaring
pcool
Then it would be called MC, not equivalent MC. You would set up the real MC
you are following on the vario which is obtainable on many instruments that
send to the PNA this setting every time you change it (LX V7 for example).
And for the purpose of giving you some information you dont already know
(the MC you did set manually) it would be useless: you would never know what
you are really doing.
Despite you have set MC to 1ms, you are flying much faster because you are
in sink since some time.
Some people think that after a long sink we can expect a "long" lift, but
generally they outland if they dont do a 90 degrees turn and run away the
sink area. The loss of altitude has to be accounted as a pure loss with no
gain expected for sure.
The precaution you mention is the STF audio that since decades already does
what you say.
"Tibor Arpas" wrote in message
rise/sink.
McCready Theory Used by Birds [email protected] Soaring 1 February 20th 13 10:17 PM
Source for a PZL 80mm McCready Ring Travis Beach Soaring 0 June 14th 07 04:05 PM
Source for a PZL 80mm McCready Ring Travis Beach Soaring 0 June 14th 07 04:04 PM
Pictures of Dr.Paul McCready at SSA Convention Gary Boggs Soaring 0 February 23rd 05 05:20 PM
McCready Speed ring for ASW-20 Jeff Dorwart Soaring 1 May 5th 04 12:58 AM
