Then it would be called MC, not equivalent MC. You would set up the real MC
you are following on the vario which is obtainable on many instruments that send to the PNA this setting every time you change it (LX V7 for example). And for the purpose of giving you some information you dont already know (the MC you did set manually) it would be useless: you would never know what you are really doing. Despite you have set MC to 1ms, you are flying much faster because you are in sink since some time. Some people think that after a long sink we can expect a "long" lift, but generally they outland if they dont do a 90 degrees turn and run away the sink area. The loss of altitude has to be accounted as a pure loss with no gain expected for sure. The precaution you mention is the STF audio that since decades already does what you say. "Tibor Arpas" wrote in message ... No, I totally would want it to be adjusted for sink and climb. LK8000 doesn't adjust for that, so it's probably not a good example/definition. What I meant is "flown MC". Its reversing the STF calculation and producing a figure from averaged airspeed, the polar and the rise/sink. Also as a precaution against a common mistake of flying so slowly in sink that you're actually achieving smaller then maximal achievable L/D I would like to have immediate warning for that (spead up!). |
McCready Theory Used by Birds | [email protected] | Soaring | 1 | February 20th 13 10:17 PM |
Source for a PZL 80mm McCready Ring | Travis Beach | Soaring | 0 | June 14th 07 04:05 PM |
Source for a PZL 80mm McCready Ring | Travis Beach | Soaring | 0 | June 14th 07 04:04 PM |
Pictures of Dr.Paul McCready at SSA Convention | Gary Boggs | Soaring | 0 | February 23rd 05 05:20 PM |
McCready Speed ring for ASW-20 | Jeff Dorwart | Soaring | 1 | May 5th 04 12:58 AM |
