Inertial vario
Old October 28th 14, 11:48 PM posted to rec.aviation.soaring
Andrzej Kobus
Default Inertial vario
On Tuesday, October 28, 2014 3:03:42 PM UTC-4, s6 wrote:
Hi
Anybody from Australia or Germany has flown with the Vaulter inertial vario
made by Wharington Smith instrument from Australia?
Comments, opinions.
Thank you,
Gilles
There is a short review on the segelflug.de, but don't get too excited they are only selling on the European market. They don't have plans to launch on the US market for at least 6 months so we can't have it for the next Spring. I am not sure what is driving their decision, maybe lawyers again.
Old October 29th 14, 10:12 AM posted to rec.aviation.soaring
7C
I've just had one installed on in my LS4. Should be flying it in NZ SI Regionals in November. Looks good in the panel I ordered for delivery to NZ.
Old October 30th 14, 02:55 AM posted to rec.aviation.soaring
waremark
What's special about this vario? Better than other modern varios?
Old October 30th 14, 11:50 AM posted to rec.aviation.soaring
7C
Mostly because it's pretty much just a vario...
It means that I'm not going to have to memorise a manual, or wonder what 4 differently shaped and coloured symbols mean I didn't want another Flarm display or more navigation stuff to program. I don't want 4 buttons and two rotary knobs to play with when I'm flying. I want it to beep telling me what the air is doing, not what it thinks I should be doing... Ie, I'm a bit of a luddite when I'm flying!
My primary excuse was for the instantaneous wind. I really struggled with circling wind calculations flying in Omarama. Part of that is that you aren't turning enough and part is a bug in XCSoar which makes wind calculation unreliable when it's very windy. With the Vaulter the wind will update constantly regardless of how I'm flying. This should help with ridges and a bit with wave. If it hadn't been for that I would probably have just bought a Borgelt B400. (I may still to replace the mechanical)
The A/H functionality is more an emergency sanity thing rather than a primary buying reason. I had a lenticular form around me last season, it wasn't a problem but it happened so fast and literally out of the blue! It will be nice knowing I have something more than blind luck for that 1 in a 100 random occurrence!
Mel
Old October 30th 14, 07:42 PM posted to rec.aviation.soaring
Mel
If you don't want to 'memorise a manual, or wonder what 4 differently shaped and coloured symbols mean' you definitely DON'T want to buy a B400. It's got to be the most un-unintuitive vario that I have ever had the misfortune to fly with.
Old October 30th 14, 07:55 PM posted to rec.aviation.soaring
7C
Really? It beeps differently for up and down, has one button which turns off down beeps or gives average and a volume control. Doesn't do anything else! Are you sure you're not thinking of a B500?
Old October 30th 14, 06:15 AM posted to rec.aviation.soaring
BillT
Pls give us a report after the SI regionals (& good luck!) Thanks, Bill
Inertial sensing in Butterfly Vario, TE vs Airmass indicators Marc - Butterfly Avionics Soaring 17 June 17th 13 12:16 PM
shoulder harness inertial reels Stu Fields Rotorcraft 0 September 9th 09 07:52 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Replacement shoulder belt inertial reels in a Cherokee. [email protected] Owning 1 January 3rd 09 06:03 PM
Inertial reel shoulder harness - retro fit? Casey Wilson Piloting 16 March 24th 06 02:20 PM
