On Friday, October 31, 2014 8:08:06 AM UTC-7, jfitch wrote:
On Thursday, October 30, 2014 3:54:54 PM UTC-7, Andy Blackburn wrote: On Thursday, October 30, 2014 10:09:13 AM UTC-7, jfitch wrote: On Thursday, October 30, 2014 4:59:22 AM UTC-7, Andy Blackburn wrote: On Wednesday, October 29, 2014 1:38:45 PM UTC-7, jfitch wrote: One problem complicating this is that thermals are normally accompanied by local horizontal "gusts" which are actually sustained flow field (as mentioned in some of the above posts). Signal to noise can always be a problem - the good news should be that if the air is really going up you ought to be able to pick that out, but I agree if there is turbulence on the thermal entry that has greater velocity than the thermal itself and/or goes on for a long way a human observer won't be able to integrate the net effects for long enough to figure out what is going on. A computer might have a better shot at it. However, if the phugoid response difference is your only signal, that is going to be a challenge. I was saying something a bit different. In the case of a horizontal gust the main dynamic reaction from the glider is some modest horizontal deceleration and a slow pitch up followed by a slow pitch down (post-gust) from the phugoid response. In a thermal entry you get mostly a vertical surge plus some downward pitching moment from the short period response if the glider has static stability. Most modern gliders don't benefit from being flown at the aft limit but even if you do the response should be different. If you have a glider that generates a nose-up pitching moment from an increase in angle of attack, that would be a real handful to fly even under benign conditions. This is at least some of the reason why thermals "feel" different. That surge you feel has a different linear acceleration vector and a different (opposite) pitch response. If the Butterfly uses Kalman filters to separate out the air mass movement that is exactly what I was suggesting (and attempting to explain why) - you ought to be able to pick out the air movement vector IF you have the right onboard sensors AND you have an accurate enough dynamic model for the glider. The better the model represents all the aerodynamic and inertial coefficients the more accurate the answer should be. I could also imagine intelligently looking not just at the instantaneous airmass velocity, but also the profile of thermals for a given day to help identify good ones from bad ones, though that is a much more complex matter. Thermals also have temperature gradients - though the experiments I participated in recently were not conclusive. 9B I agree mostly. A horizontal gust WILL produce a vertical acceleration and this can be quite strong due to the V^2 term in dynamic pressure. This can produce a instantaneous response in the glider that is pure free body effect, superimposed on static aerodynamic stability, and they will normally be opposite. In a vertical gust the effects will in the same direction. In my experience, in strong thermals the dynamic accelerations will be of far greater magnitude than static stability effects, swamping that signal (and eliminating the need, for the most part, to model the glider dynamics closely). On weak days or with soft well behaved thermals, maybe - but where I fly we are rarely cursed with those conditions. The horizontal air movement in and around thermals is far greater than I thought, until I "instrumented up". Once you know its there, you begin to look critically for confirming evidence and discover that is is there. I learned something from the discussion I need to find a way to go test.. I've always had the sense that a decent thermal gave you a surge that felt a little tail-high. Like you were being shoved upward and a bit forward. Stick thermals have the opposite pitch sensation as do horizontal gusts - though I am less good at recognizing gusts except as random vario readings. I need to confirm whether the sensation comes from the coupling of the thermal's transient vertical air movement through to short-period pitch response via the increase in AOA. A little math and some flying are in order. 9B Or just basic statics: if the CG is ahead of the lifting center of the wing the upward acceleration causes a pitch down moment. True that - I wonder if one effect is reliably larger than the other for a typical glider with a cg midway between forward and aft limits. In any case a solid thermal entry should generate some nose-down pitch. Also seems that if you want to feel what's going on don't mess with the elevator too much.. 9B |
Think in terms of the relative wind and the trim speed:
When we enter the thermal, the airmass changes, there is a upward component, the nose pitches down relative to the horizon, but the trim speed remains the same. We see a pitch down but the relative wind is the same. The opposite is true leaving the thermal or in a downdraft: it seems we can't get the nose down far enough as the downdraft pitches the nose up, or at least decreases the AoA. Like Moffat said (paraphrase) it's easier to accelerate in lift than sink. |
