Where is the LX S80?
Old November 3rd 14, 01:33 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Where is the LX S80?
On Monday, November 3, 2014 3:15:06 AM UTC-8, pete purdie wrote:
...An important finding is that above about
one-third of the distance to the inversion, there is no significant
temperature difference between the thermal and surrounding air; near the
inversion the temperature is actually lower since the warmer air above the
inversion is being mixed down around the rising air. Humidity is a
significant indicator, H2O molecules being lighter than O2 or N2.
So thermals rise, not because of the sun heating the ground and making a bubble of warm air that breaks free, but because somehow a more humid bubble of air is created. What mechanism creates the bubble of humidity?
9B
  #82
Old November 3rd 14, 01:38 PM posted to rec.aviation.soaring
9B
Differences in ground surface condition.
There is also a variation in electrical potential between thermals and surrounding air. This was explored in the 70's.
UH
  #83
Old November 3rd 14, 02:01 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
As should have been clear from what I wrote, in the bottom third of the
thermal the air is still warmer, but steadily mixing in surrounding air.
Once properly formed the momentum of the tons of air moving is presumed to
keep the circulation active. Air close to the ground is also more humid
which increases the buoyancy. We did not fully model the mechanism, just
took measurements that illustrated the scale and characteristics of
meso-scale air motion in a range of situations, including convective
weather.
9B
  #84
Old November 3rd 14, 02:14 PM posted to rec.aviation.soaring
krasw
9B
No it's differences in temperature. Humidity is transferred up to inversion layer with thermals (closed system), and air above inversion is much drier.. It's a good point however that warmer air from inversion is sucked down, so temperature sensing might be useless there. I don't see it totally useless when searching for a thermal closer to ground. Interesting topic.
  #85
Old November 3rd 14, 02:29 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Enough to charge the batteries on one's FES? ;-)
  #86
Old November 3rd 14, 02:38 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Not entirely sure I buy momentum as a first-order effect since blue thermals don't typically overrun the top of the invasion level by very much, so I can't imagine the top 2/3 of the thermal is simply momentum. Also, if it's thoroughly mixed from a temperature perspective wouldn't it also be mixed from a humidity perspective as well so it wouldn't be rising from having higher humidity either?
Curious.
9B
  #87
Old November 3rd 14, 03:08 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Like I said, we didn't attempt to fully model the
mechanism.
Richard Feynmen: 'If the measurements don't agree with
the theory, then the theory is probably wrong. If they do,
the theory might be right.'
t=
o
keep the circulation active. =20
thermal=
I
it's
f=
hig=
Curious.
9B
  #88
Old November 3rd 14, 04:30 PM posted to rec.aviation.soaring
OK btt..
The S80 arrived after some desperate 6 month delay last week and went directly into the ship.
Flying with it the first time yesterday 3.5 hours showed exelent performance.
Great visibility even with sunshine and blue sky.
I like the fast response without any sign of being nerveous.
Even with response times of just 1.5s..
The big and bright display could be noticed without even having my eyes pointing to the dashboard.
Software ins not at the feature level of the V7 yet but will be soon as the developer promised.
So thumbs up for now!
P.
  #89
Old November 3rd 14, 06:13 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
mechanism.
Truth.
  #90
Old November 4th 14, 08:03 AM posted to rec.aviation.soaring
krasw
weather.
9B
Interesting study:
http://journals.ametsoc.org/doi/abs/...B%3E2.0.CO%3B2
Figure 6 gives quite good overview of temperature and humidity variability during (weakish) convective activity. Temp. differences are appr. 0,5 deg and humidity 1 g/kg close to ground.
Other Weckwerth papers are worth reading too, IMHO.
