On Monday, November 3, 2014 6:15:05 AM UTC-8, pete purdie wrote:
Once properly formed the momentum of the tons of air moving is presumed to keep the circulation active. Not entirely sure I buy momentum as a first-order effect since blue thermals don't typically overrun the top of the invasion level by very much, so I can't imagine the top 2/3 of the thermal is simply momentum. Also, if it's thoroughly mixed from a temperature perspective wouldn't it also be mixed from a humidity perspective as well so it wouldn't be rising from having higher humidity either? Curious. 9B |
Like I said, we didn't attempt to fully model the
mechanism. Richard Feynmen: 'If the measurements don't agree with the theory, then the theory is probably wrong. If they do, the theory might be right.' At 14:38 03 November 2014, Andy Blackburn wrote: On Monday, November 3, 2014 6:15:05 AM UTC-8, pete purdie wrote: Once properly formed the momentum of the tons of air moving is presumed t= o keep the circulation active. =20 Not entirely sure I buy momentum as a first-order effect since blue thermal= s don't typically overrun the top of the invasion level by very much, so I = can't imagine the top 2/3 of the thermal is simply momentum. Also, if it's = thoroughly mixed from a temperature perspective wouldn't it also be mixed f= rom a humidity perspective as well so it wouldn't be rising from having hig= her humidity either? Curious. 9B |
OK btt..
The S80 arrived after some desperate 6 month delay last week and went directly into the ship. Flying with it the first time yesterday 3.5 hours showed exelent performance. Great visibility even with sunshine and blue sky. I like the fast response without any sign of being nerveous. Even with response times of just 1.5s.. The big and bright display could be noticed without even having my eyes pointing to the dashboard. Software ins not at the feature level of the V7 yet but will be soon as the developer promised. So thumbs up for now! P. |
Surprised that software features of S80 are not up to V7 currently. What is excluded?
Wonder whether it will become a better vario since it has more sensors. It costs much more than V7. |
On Tuesday, November 4, 2014 6:00:49 AM UTC-8, waremark wrote:
Surprised that software features of S80 are not up to V7 currently. What is excluded? Wonder whether it will become a better vario since it has more sensors. It costs much more than V7. I have tested the S80 on the bench and it has more features than the V7. Navigation, AHRS etc. Richard www.craggyaero.com |
I just received my new S80 vario.
It might be helpful for those of us who are just now installing and calibrating our units to share. Software bugs? TE vs electronic compensation? Plumbing the TE line when shared with a mechanical vario (Sage vs Winter vs Borgelt). Flarm display results and tuning. Two way communication with a PDA with SeeYou/GN2/etc. |
Logbook is not implemented yet and Englisch only at the moment..
Different numbers in cruise/circling mode are not implemented like in the V7 AT least the undervolt warning worked for me, as I emptied both of my batteries...:-) |
On Tuesday, November 4, 2014 10:13:57 AM UTC-8, wrote:
Logbook is not implemented yet and Englisch only at the moment.. Different numbers in cruise/circling mode are not implemented like in the V7 AT least the undervolt warning worked for me, as I emptied both of my batteries...:-) The V7 is a lovely instrument. If the manufacturer were able to make an extension module that included the inertial vario parts and modify the software to incorporate the module it would be pretty attractive. Craig 7Q |
On Monday, November 3, 2014 7:15:06 AM UTC-8, pete purdie wrote:
Like I said, we didn't attempt to fully model the mechanism. Richard Feynmen: 'If the measurements don't agree with the theory, then the theory is probably wrong. If they do, the theory might be right.' Truth. |
On Monday, November 3, 2014 6:38:22 AM UTC-8, Andy Blackburn wrote:
Not entirely sure I buy momentum as a first-order effect since blue thermals don't typically overrun the top of the invasion level by very much, so I can't imagine the top 2/3 of the thermal is simply momentum. Also, if it's thoroughly mixed from a temperature perspective wouldn't it also be mixed from a humidity perspective as well so it wouldn't be rising from having higher humidity either? Curious. 9B I did the simple physics on this. A volume of air rising at 600 fpm with no other forces acting on it other than gravity has enough momentum to rise an additional 1.6 feet before its upward velocity reaches zero. I am now officially at a loss as to why thermals go up if there is no temperature difference versus the surrounding air. 9B |
