FES - Take 2
Old November 3rd 14, 07:14 PM posted to rec.aviation.soaring
kirk.stant
Default FES - Take 2
On Sunday, November 2, 2014 11:09:18 AM UTC-6, Andrzej Kobus wrote:
Kirk, you are simplifying things. What about a situation when the engine develops on partial power. You just don't fly away. You are quickly in very difficult situation.
When I used to fly pure sailplanes and I saved myself down to 600 feet quite safely. I would never attempt to start the engine less than 1500 feet, unless I had a really long field in front of me allowing for all kids of options. In reality since I started flying a self launcher I restart at 1500-2,000 feet depending on terrain.
Jet can also have starting issues as experience suggest. I know of at least one situation when a jet engine in a glider developed only partial power and the pilot barely got away from having a really bad day as he tried to start a bit low. I bet he will never do that again.
AK
Andrzej, I understand the case for a self-launcher, with a much draggier and complicated power system. But aren't the "turbo's" supposed to be simple and easy to start, and have about as much drag as the landing gear when extended? Not having flown either SLS or sustainers, I admit I'm just guessing here.
Kirk
Old November 3rd 14, 08:57 PM posted to rec.aviation.soaring
JS
Just like winch tow, auto tow, landings on tow, spins, etc...
I think a self-launch endorsement is good training. Each is an eye-opener.
Without training in these elements there's an increased chance of misconception.
If a self-launch endorsement isn't available where you are, at least read Eric Greenwell's guide to self-launch sailplanes.
Yes, the FES is a different animal, but as far as I can tell there's no 100% guarantee.
Old November 3rd 14, 08:48 PM posted to rec.aviation.soaring
John Galloway[_1_]
an=
simple=
when
ex=
guessin=
g here.
Kirk
The drag on a glider with an extended but non-running two stroke "turbo"
is similar to having about half airbrake extended - a lot more more than
just having the gear down.
John Galloway
Old November 3rd 14, 10:08 PM posted to rec.aviation.soaring
Renny[_2_]
I definitely agree that there are no guarantees that a sustainer will always start, but one of the real benefits of the FES is that if it does not start, there is no additional drag penalty.....
Thanks - Renny
an=
simple=
when
ex=
guessin=
g here.
Kirk
John Galloway
