Volkslogger Date Corruption
Old November 15th 14, 01:53 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Volkslogger Date Corruption
On Sat, 15 Nov 2014 11:40:35 +0200, Ian wrote:
Finally any comments. Nano vs Colibri II. Any others devices I should
look at? (I have got a while to do my window shopping, the prayer
process will still take many weeks.)
You might also consider the EW MicroRecorder - £240 + VAT + P&P.
Its a completely self-contained brick (115x85x25mm, 280g) with an
external puck-style GPS antenna and built-in pressure sensor. It has an
internal, user-swappable battery, takes a 12v external supply and has a
USB connector for configuration and downloads. Both the 12v and USB
supplies charge the battery. Uses an SD card (supplied) to store IGC
files. It is fully IGC certified.
I have one and like it.
Its biggest disadvantage is that the internal battery is NiMH and can't
be disconnected: the combo of NiMH self-discharge rate and the power
drain due to the soft power switch means that I have to remember to
charge it every month or two during the off season. During the gliding
season you never charge it: if you connect it to the glider's battery
during rigging it will be fully charged by the time you derig.
HTH
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Civil Air Patrol Commander's Corruption Larry Dighera Piloting 9 October 6th 07 04:16 PM
Contracts and Corruption,partisanship and distractions =Neocon takeover fusion Naval Aviation 0 May 24th 07 09:22 PM
FSDO enforcement- GPS before effective date - which date to put in Aircraft Log for Part 43? Ron A. Instrument Flight Rules 18 March 15th 06 02:30 PM
Corruption in the US military John Penta Military Aviation 5 October 3rd 03 10:03 PM
GPS 90b out of date? Roger Long Piloting 2 August 8th 03 03:58 PM
