How to determine if your ASG29 has the large or small panel?
Old November 19th 14, 05:27 PM posted to rec.aviation.soaring
Dave Nadler
Default How to determine if your ASG29 has the large or small panel?
On Wednesday, November 19, 2014 10:54:34 AM UTC-5, waremark wrote:
...the voice process is too slow for a real threat.
...I think it takes a fraction of a second to take in with
peripheral vision the clock face display indicating the direction
of the threat, almost simultaneously scanning outside the cockpit.
Right - Voice is not the fastest. It takes a while for the message,
and it can get lost (for example if you're receiving a radio message).
The fastest is a large simple graphical "pointer" in your field
of vision, accompanied by a warning alarm. A visual presentation
is less effective when:
- its not already in your field of vision (turning head takes lots of time)
- poor contrast
- a complicated/busy/fussy display cannot be comprehended instantaneously
- buried low on the panel
Voice helps in the above situations...
Here's the SN10 presentation (4 O'clock high):
http://www.nadler.com/sn10/FLARMcol.png
We also changed the Butterfly presentation from the original to
make comprehension instantaneous...
Hope that helps frame the problem!
Best Regards, Dave
PS: We built many voice applications (phone), some quite notorious ;-)
Time for user to comprehend and use is always an issue.
Think about various annoying automated phone services you've used.
Old November 19th 14, 06:50 PM posted to rec.aviation.soaring
The problem is also how the voice function is implemented in the LX. The TR-DVS is much faster and very optimized to its only purpose, and it's decision when to alarm the pilot is much more reliable. However as always there are probably different opinions...
Cad drawing for ASW27 or ASG29 instrument panel Larry Goddard Soaring 16 December 30th 18 07:19 PM
ASG29 For Sale YourNameHere Soaring 0 May 29th 14 01:04 PM
How to simply determine the L/D of your glider jan Soaring 41 January 17th 11 01:05 AM
How do you determine remaining life of Ceconite covering? [email protected] Aviation Marketplace 2 October 8th 05 01:19 AM
Invest small Earn Large ($20 000+) promethean General Aviation 0 October 3rd 03 06:08 AM
