On 24 Nov 2003 09:13 AM, RobertR237 posted the following:
I have gone through three of the little buggars and all three failed in the switch, not the brushes or bearings. I had a brand new one which ran for about 10 seconds out of the box, and then died due to a faulty switch. Not counting defective part failures, I have a tough time seeing how I could possibly wear mine out, as little use as it sees. For the things I use it for, nothing else will really do but otherwise it often doesn't come out of the toolbox for months at a time. I believe that if you find yourself using a dremel tool that much you need to consider buying some real tools (i.e. bigger grinders) since the dremel isn't really suited for continuous use. Not to mention the extra time spent since using the dremel is slow compared to a larger grinder or cut off tool. I have a pair of 1/4" electric die grinders (one I bought, then got another for christmas) each with a different bit, a couple of angle grinders, a 3" cut off tool in addition to my normal bandsaw, hacksaw, and bench grinder/sander. If none of those will do the job, only then does the Dremel come out. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
In article , Del Rawlins
writes: I had a brand new one which ran for about 10 seconds out of the box, and then died due to a faulty switch. Not counting defective part failures, I have a tough time seeing how I could possibly wear mine out, as little use as it sees. For the things I use it for, nothing else will really do but otherwise it often doesn't come out of the toolbox for months at a time. I believe that if you find yourself using a dremel tool that much you need to consider buying some real tools (i.e. bigger grinders) since the dremel isn't really suited for continuous use. Not to mention the extra time spent since using the dremel is slow compared to a larger grinder or cut off tool. I have a pair of 1/4" electric die grinders (one I bought, then got another for christmas) each with a different bit, a couple of angle grinders, a 3" cut off tool in addition to my normal bandsaw, hacksaw, and bench grinder/sander. If none of those will do the job, only then does the Dremel come out. That would depend on what you are using it for. It is the greatest and most used single tool I have used on building my fiberglass aircraft. With a little practice you can literally use it to remove one layer of paint at a time. I use it mainly to remove excess glass and trim sharp edges. Larger grinders are useless for what I have used it for. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
Proposed new flightseeing rule | C J Campbell | Home Built | 56 | November 10th 03 05:40 PM |
