On Wednesday, 10 December 2014 08:53:29 UTC+2, Surge wrote:
We'll have to wait until the investigation results are out but the things that usually kill experienced pilots is the simple stuff such as a stall and spin-in close to the ground. Hopefully there will be some GPS traces to help investigators figure out what went wrong. Does the ASH-25 EB28 have the same limitation as the Nimbus 4's where you can exceed VNE or overstress the airframe if you try to recover from a vertical nose down attitude? I would like to see a glider which you cannot overstress during vertical nosedive.... SG-38? Space shuttle? |
On Wednesday, 10 December 2014 11:19:54 UTC+2, krasw wrote:
I would like to see a glider which you cannot overstress during vertical nosedive.... SG-38? Space shuttle? That's not what I meant. I meant can the ASH-25 EB28 recover from an accidental spin/wing drop situation (where the nose is pointing at the ground), without exceeding VNE or over stressing the airframe? |
Wouldn't get certification if it couldn't.
At 11:25 11 December 2014, Surge wrote: On Wednesday, 10 December 2014 11:19:54 UTC+2, krasw wrote: I would like to see a glider which you cannot overstress during vertical nosedive.... SG-38? Space shuttle? That's not what I meant. I meant can the ASH-25 EB28 recover from an accidental spin/wing drop situation (where the nose is pointing at the ground), without exceeding VNE or over stressing the airframe? |
