As previously said - look in the manual and TC for directions from the manufacturer as to what source to use. Usually they will specify a source for the ASI system as the placard limits are in IAS using those sources. I've often found they will specify on for the altimeter too though as UH says it doesn't matter much for the altimeter. Paul Bickle and Dick Schraeder's tests usually found that the most accurate static sources are ones well aft on the fuselage sides so those should be used for varios. Static sources on the multi probe are probably very accurate too. If you have both aft fuselage statics and a multi probe you could use the fuselage ones for the mechanical vario and the multi probe for the electronic vario so that the two don't suffer from interference.
PANEL PLUMBING | Travis Beach | Soaring | 3 | December 5th 07 10:00 PM |
PANEL PLUMBING | Travis Beach | Soaring | 0 | December 5th 07 02:16 PM |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Plumbing for a CAI 302 + Schuemann B-Box | Mark Grubb | Soaring | 1 | June 12th 04 03:39 PM |
