Pilatus B4 PC-11 wing repairs
Old January 7th 15, 03:05 AM posted to rec.aviation.soaring
WB
Default Pilatus B4 PC-11 wing repairs
I know our club has significant expertise in destroying them, if that helps.
Try George Taylor at Van Sant airport in Pennsylvania. At one point, the FBO there was an importer for Pilatus; there were at least a half-dozen on the field. Numbers that may work are either: 610-847-1119 or 610-847-8494.
Erik Mann (P3)
Sorry - I made that more cryptic than it needed to be. George is the mechanic at Van Sant. He's probably got more experience than anyone in the US doing inspections and also repairs on Pilati.
Thanks P3. I got a chuckle out of your first statement there. Not to laugh at your club's misfortune. It's more a nod at the gallows humor and a familiar sentiment. We live in constant fear of what is going to get busted next.. It's mostly small damage with us, but sometimes it seems to be a constant barrage of small damage.
I will forward George Taylor's info to my friend with the crippled B4.
All the best,
WB
Old January 7th 15, 02:20 PM posted to rec.aviation.soaring
Luke Szczepaniak
I think this is may be an issue at most if not all clubs, I am always
amazed how carelessly some members treat equipment....
Luke
Old January 7th 15, 06:03 PM posted to rec.aviation.soaring
Luke
We "retrain" some club members by having them work on the repairs along with the rest of us...... ;-)
Old January 9th 15, 12:18 AM posted to rec.aviation.soaring
On Wednesday, January 7, 2015 at 12:03:09 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Luke
As it should be
Old January 7th 15, 04:58 PM posted to rec.aviation.soaring
Papa3[_2_]
On Tuesday, January 6, 2015 10:05:41 PM UTC-5, WB wrote:
Thanks P3. I got a chuckle out of your first statement there. Not to laugh at your club's misfortune. It's more a nod at the gallows humor and a familiar sentiment. We live in constant fear of what is going to get busted next. It's mostly small damage with us, but sometimes it seems to be a constant barrage of small damage.
All the best,
WB
Our poor Pilatus was knocked around a couple of times - nothing serious - until one day when she was being towed out to the launch line during a strong ridge day with a single wing walker. Suddenly the Pilatus was executing beautiful Immelman in at about 20 feet AGL. Unfortunately, the maneuver lacked the requisite 180 roll in the second half, and the aircraft ended up upside down with a busted wing and a broken "back".
P3
Old January 7th 15, 08:14 PM posted to rec.aviation.soaring
Cookie
Erik,
I think you are conflating two incidents. I was "there" for both of them. No, I'm not a jinx. Back in those days I spent every day, all day, at the field, so whatever happened, I was there.
The first incident: NW ridge was predicted, but the wind was calm. I was helping the Pilatus pilot to bring the glider from one end of the field to the other. We untied the glider, and I had just connected a rope to the bumper of my car, and he connected it to the CG hook on the glider. Well, the predicted NW wind came all at once...a strong gust...the glider lifted off....held at the CG hook by the rope and the car, it did a sort of mini winch launch...
It got maybe 10' high and then settled back down on its wing tip...fair amount of damage, but repaired.
Second incident...Well I wasn't right there...but close.
I was the first tow of the day. Again predicted to be a ridge day, but fairly calm winds so far. The Pilatus was second on the grid for take off. After I towed to the ridge, a few minutes later, I called the tow pilot on the radio...a pilot-rep for those on the ground, to tell him the ridge was working and the thermals were strong.
The tow pilot's response to my radio call was kind of odd. He said something like," Errr, ahhhh, errrr, hey I'll get back to you!"
I thought, "OK whatever"
What I didn't know at the time was that the tow pilot was on final approach, and watched the (unattended) Pilatus rise off the ground and do a 1/2 flip, right in front of him!....The tow pilot didn't want to ruin my fun for the day, so he didn't say what happened, and I didn't find out until I landed some hours later...Glider was a "total"...
That incident resulted in a new club rule, that all gliders must either be tied to the ground, or have the spoilers held open while being moved on the ground.
We also installed a bunch of nose tie down ropes along the grid area.
Funny thing about that Pilatus...On aero tow, during ground roll and take off, you HAD to hold full forward stick....if you didn't hold it to the stop, the glider would take off and continue to climb, and then full forward stick would be useless...it would just keep climbing....You had to hold the stick forward, and do the ground roll in a nose down attitude...and it took off in that nose down attitude too....I guess the wings are rigged with a high angle?
Other wise really nice glider.
Cookie
P3
Old January 7th 15, 08:48 PM posted to rec.aviation.soaring
kirk.stant
That sounds like there was a real problem with the CG or stab/elevator rigging (or the wing incidence?) on that particular B4. Long ago, I flew a couple of B4s (no, actually, it was the same one in two different places, Vacaville and Estrella, separated by several years!) and other than pitch being a bit sensitive (kind of like a 1-26), it otherwise was an easy plane to fly. Definitely did NOT have to hold the stick forward for takeoff or tow!
Kirk
66
Old January 7th 15, 09:23 PM posted to rec.aviation.soaring
Cookie
Yeah, it seemed like a balance problem...but we ran the numbers...
Did they have CG hook? How heavy are you? Funny thing with a pilatus...the trim ballast weights go on the TAIL !! Heavy pilots need tail ballast!
So it can take a fairly light pilot without trim ballast, and as the pilot gets heavier, you add weights to the tail...If I remember, there were two "plates"...small one, big one...you could use either, or both to give proper balance...they were bolted on externally...
Cookie
Kirk
66
Old January 8th 15, 12:33 AM posted to rec.aviation.soaring
kirk.stant
Nothing unusual about aft ballast weight for a heavy pilot - got some of that in my LS6 these days! But back then, I was well under the 220 lb that the B4 flight manual says is the pilot weight that calls for the aft ballast..
And they are all CG hooks.
Was that B4 ever damaged and repaired?
Kirk
66
Old January 8th 15, 05:23 AM posted to rec.aviation.soaring
Cookie
To me, what's unusual about tail trim ballast is that as the pilot weight goes up, the ballast weight goes up too...making it easier to hit gross...
The "schweizer" way, Light pilot adds ballast, heavy no ballast...
But 220 is pretty high for not needing ballast....
But none of the "regulars" who flew this glider were anywhere near 220...more like 135 to 165....I probably weighed in at 150 back then...
Specs show "empty weight at 508#...so it looks like pilot could go all the way up to 262#.....so us 150-pounders were probably far aft on the CG...no?
If memory serves me correct, we started putting a 25 lb lead sheet under the seat...to avoid the kiting problem...
I don't know what happened to the wreck....Anybody in ACA have any info on this?
cookie
Did they have CG hook? How heavy are you? Funny thing with a pilatus....the trim ballast weights go on the TAIL !! Heavy pilots need tail ballast!
Kirk
66
Porter Pilatus PC6 at Whiteman - Fairchild Heli-Porter Pilatus PC6.JPG (0/1) MomDude Aviation Photos 1 March 9th 09 10:31 AM
Porter Pilatus PC6 at Whiteman - Fairchild Heli-Porter Pilatus PC6.JPG (1/1) MomDude Aviation Photos 0 March 9th 09 12:04 AM
Porter Pilatus PC6 at Whiteman - Fairchild Heli-Porter Pilatus PC6.JPG (1/1) - Fairchild Heli-Porter Pilatus PC6.JPG (1/1) MomDude Aviation Photos 0 March 9th 09 12:00 AM
Porter Pilatus PC6 at Whiteman - Fairchild Heli-Porter Pilatus PC6.JPG (0/1) MomDude Aviation Photos 0 March 8th 09 11:58 PM
TM6 repairs in the UK Ian Johnston Soaring 2 January 21st 06 10:26 PM
