Steve Hix writes: In article , (Peter Stickney) wrote: I don't see any X-Prize contenders carrying 1,000# of Data Acq along with them. How much would equivalent-capability gear weigh these days? Well, in the case of teh instruments and recorders, quite a bit less, (How's that for an exact figure!) and with a much lower cooling burden, as well. The telemetry stuff will also be a bit lighter, but not as much - transmitters are still pretty hefty. Of course, if you were building a 21st Century X-15, and you had 1000# (or even 450 Kg) of avaialable payload, you'd fill it up with even more stuff. Equipment expands to fill the available volume & weight, after all. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Spaceship 1 hits 212,000 feet!!!!!! | BlakeleyTB | Home Built | 10 | May 20th 04 10:12 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 04:46 AM |
Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 03:52 AM |
