soaring history
Old January 22nd 15, 12:54 AM posted to rec.aviation.soaring
Default soaring history
Steve,
you are right, good ground handling equipment is a must, the one man wing rigger is also a must, I am working on a hydraulic ramp jack right now, my trailer is a minden tube type and the fixtures are easy to use. Once the weather gets good I leave it assembled and have built a tow bar that connects to my tail dolly and i tow the 17 to the runway and off with my car. It is a tank but in the air it will run and run. My water ballast system was real funky so I removed it and now am in the dreaming up of a new system, that is the beauty of experimental aircraft and old airworthiness limitations. It has a forward hinged canopy and I took the fixed panel out and built it so it now goes up with the canopy, new panel, wiring 5 point harness, moved the brake to the stick and much more, and more to do. Cant wait to get the bags out and see what is there and fly with water. Look for me on OLC, I fly out of Bend Oregon and lots of good soaring to you to, I like to say "old glass kicks ass".
John Bentley
On Tuesday, January 20, 2015 at 9:18:30 PM UTC-8, Steve Leonard wrote:
On Tuesday, January 20, 2015 at 12:51:12 PM UTC-6, wrote:
I have many hours in a Nimbus 2 and it was exciting to get into a ASW 17 knowing that they went head to head in the early 70's as the best in their class. It is a truly big sailplane, 100lbs heavier than my Nimbus was but goes like stink and I can keep up with all friends, most of the time at 1/4 the cost, just need some good friends to help me put it together. It is really fun to know who and when it was flown in competition, i can see Rudy's sailplane (now mine) in the line up at the 1974 and 75 National championships where he finished 8th and 25th. That is fun, now it is time for me to run like Rudy.
I need to step up my game, too. I have about 600 hours in the 604 that AJ Smith use to race, and about 300 hours in the Nimbus 3 that George Moffat and Ray Gimmey raced so successfully. A good one man rigger helps a lot. The 604 is solo rigging capable with the factory trailer and my one man rigger. Takes about as long as it does to solo rig the Nimbus 3.
Old January 22nd 15, 03:51 AM
OregonGliderPilot OregonGliderPilot is offline
Junior Member
First recorded activity by AviationBanter: Sep 2009
;895414]Steve,
John Bentley
On Tuesday, January 20, 2015 at 9:18:30 PM UTC-8, Steve Leonard wrote:[color=blue][i]
If you might not be using your water ballast system in the future, and it is or is close to being serviceable, I know another local ASW17 that would benefit.
Thanks, Martin
Old January 22nd 15, 11:37 PM posted to rec.aviation.soaring
On Wednesday, January 21, 2015 at 11:43:05 PM UTC-8, OregonGliderPilot wrote:[color=blue][i]
;895414 Wrote:
Steve,
ass".
John Bentley
On Tuesday, January 20, 2015 at 9:18:30 PM UTC-8, Steve Leonard wrote:-
is fun, now it is time for me to run like Rudy. -
would benefit.
Thanks, Martin
OregonGliderPilot
I have yet to confirm the size of my bags, but in my log book there is an entry to up the max gross weight of the aircraft to 1600lbs with the installation of larger bags which were installed, that would bring a wing loading of 10lbs per square foot, can you imagine what that would be like?
send me your tel number and I will let you know what I find when I pull the bags.
Old January 23rd 15, 08:15 PM posted to rec.aviation.soaring
JS
John:
The ASW17 will benefit greatly from a one-man rigger.
As noted in a prior thread about ASW20 ballast bags, if your bags are shot try sending them as a template to RPR.
Regarding the ramp jack, have a look at one of the "Uncle Fuzzy" trailer mods which is an alternative method to hydraulic. He isn't with us any more, but the videos are. Link below.
Many original 17s had insufficient wheel brake. Believe some people fitted a Blanik wheel/brake, which should be readily available now. This was addressed in the 17B with dual drum brakes. An alternative is to get a motorcycle shop to reline and arc the shoes. For example, Vintage Brake in Sonora, CA.
www.vintagebrake.com
(previously a partner in 17045)
https://www.youtube.com/watch?v=0abKXYtBlu8
Old January 25th 15, 03:10 AM posted to rec.aviation.soaring
I'm not very qualified to reflect on Rudy's great history, but I'll add a few memories. I fly at Ionia where he based his gliders. One contribution to soaring was Rudy and his sons promoting the annual regional at Ionia for decades. He had 4(?) sons that all fly gliders, including Eric who is the IGC President. I remember putzing with my newly acquired ASW24B in 1998 just after Frank W. delivered it (1800 miles in winter), and Rudy stopped by to say hi and commended me on my selection (Rudy owned and loved the 24). I was somewhat speechless when he approached me because I felt that I was in the presence of greatness. I later added winglets to my 24 that he and another friend designed, which later appeared on the 29. A few years later some friends and I purchased his hangar to continue the tradition of soaring at Ionia. Soaring history and Rudy Mozer are almost the same meaning.
A great site for soaring history buffs! Nick Olson[_3_] Soaring 0 November 7th 12 02:55 PM
Soaring history question Don Pyeatt Soaring 2 July 24th 12 04:46 PM
2011 Southwest Soaring Championships - Labor Day Weekend at Turf Soaring Tuno Soaring 0 August 26th 11 12:49 AM
Own a piece of soaring history [email protected] Soaring 0 November 7th 08 11:09 PM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
