Hi Roderick,
Just FYI, the overall size of the Oudie 2 is nearly identical to the overall size of your iPAQ. The Oudie 2 and Oudie 2 Lite a 135 x 86 x 14 mm (5.3 x 3.4 x 0.55 inches) in size. Also, the Oudie2 doesn't need as large of a cradle as some of the nice iPAQ cradles were. However, the Oudie 2's screen is much larger and much, much, much easier to read in sunlight. It is also supplied with a power/data cable and adapters for connection to most soaring flight instruments. If you are using a RAM or gooseneck arm to mount your iPAQ in the glider, I have a $12 adapter which can be used to connect the Oudie's cradle to a RAM or RAM-GN3-238 diamond shaped gooseneck adapter. The Oudie 2 has been extremely popular. If you buy one, you won't regret it. They are $375 for the Oudie 2 Lite and $625 for the Oudie 2 with SeeYou Mobile Lifetime License for Oudie. http://www.cumulus-soaring.com/seeyou.htm I also have a good deal on a new Oudie 2 which is 1.5 years old. It is supplied with SeeYou Mobile Lifetime License for $525 ($100 off). It has never been used - other than software upgrades by me. I'm selling it at a discount because it is not quite the latest hardware version - so it may not be quite as fast or quite as power efficient as the current Oudie 2 units. It comes with all the standard accessories and in its original box. Best Regards, Paul Remde Cumulus Soaring, Inc. "XXL" wrote in message ... On Thursday, January 22, 2015 at 1:09:35 PM UTC-6, wrote: On Thursday, January 22, 2015 at 9:26:10 AM UTC-6, XXL wrote: Thanks for the support on this. It seems to be down to the internal battery now, but those seem difficult to find as well - V6HR, but will look around for something today. I do have a 3955 as well, but same issue - need a new battery for that. I've been too busy teaching the past year or two, and haven't had a chance to use my devices, but want to get them updated for the coming season, and use them with Condor. Cheers, Roderick Rod, throw that 3955 as far as you can in the general direction of your trash can. I still have one too but just as a backup for my Avier. Buy one of those or an Oudie and you won't look back. I hated flying a final glide in contests trying to decipher what the IPAQ was not allowing me to see with the sun at the 'wrong' angle. The newer screens are so much better, it not even funny. IPAQ's time has come and gone. Herb, I agree, it probably does not make much sense to bring these things back to life, but want to figure out the best way to utilize what little space I have in the Libelle. Cheers, Roderick |
Paul,
Also a great idea. As you know I've been using the Cambridge software since its inception, and it worked well with my 302. However, over the years I've had more and more problems with the PDAs, and think it' finally time to make a change, one that is both economical and something that will be around for years. I have SeeYouMobile - the main reason I was looking to get the iPAQs up and running, but an Oudie 2 or the Binatone may be the better way to go. I'll be in touch late next week. Cheers, Roderick |
Hi Roderick,
One major advantage to the Oudie2 solution is the included cabling and cradle. You can spend a lot of money on cables or BlueTooth modules for the "low cost" PNA devices. The Oudie 2 is supplied with a nice power/data cable and configurable adapters and a nice basic cradle. Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________________________ "XXL" wrote in message ... Paul, Also a great idea. As you know I've been using the Cambridge software since its inception, and it worked well with my 302. However, over the years I've had more and more problems with the PDAs, and think it' finally time to make a change, one that is both economical and something that will be around for years. I have SeeYouMobile - the main reason I was looking to get the iPAQs up and running, but an Oudie 2 or the Binatone may be the better way to go. I'll be in touch late next week. Cheers, Roderick |
Yup, what Paul said.
I bought a brand new Streak for $100 and XCSoar was free but the Bluetooth module and cable added at least $300 to the package. Dan On 1/23/2015 9:04 AM, Paul Remde wrote: Hi Roderick, One major advantage to the Oudie2 solution is the included cabling and cradle. You can spend a lot of money on cables or BlueTooth modules for the "low cost" PNA devices. The Oudie 2 is supplied with a nice power/data cable and configurable adapters and a nice basic cradle. Best Regards, Paul Remde Cumulus Soaring, Inc. _____________________________________ "XXL" wrote in message ... Paul, Also a great idea. As you know I've been using the Cambridge software since its inception, and it worked well with my 302. However, over the years I've had more and more problems with the PDAs, and think it' finally time to make a change, one that is both economical and something that will be around for years. I have SeeYouMobile - the main reason I was looking to get the iPAQs up and running, but an Oudie 2 or the Binatone may be the better way to go. I'll be in touch late next week. Cheers, Roderick -- Dan Marotta |
Paul,
Getting more and more promising. I may give you a call later today. Thank you. Roderick |
Let me again suggest using a Kobo mini e-reader running XCSoar. The screen is black and white but is very readable in sunlight. You can make one up for $100 or a little more if you can't make the internal connections yourself.
I have made six of these for myself and other club members. Not as high end as the commercial products, but way better than any Ipag. Directions are on the web, this one is a good starting point. http://www.50k-or-bust.com/Kobo%20XC...Notes%2001.pdf Gary |
Interesting solution, Gary, but a bit large for the cramped area I have in the glider.
Thanks, Roderick |
Volkslogger to HP IPAQ hx4700 Connection | RN | Soaring | 0 | February 17th 12 05:57 PM |
Ipaq HX4700 for sale | 8H | Soaring | 0 | June 8th 10 06:28 PM |
HP iPaq hx4700 issues | GK[_1_] | Soaring | 3 | January 4th 08 07:39 PM |
For Sale: IN THE COCKPIT VHS VIDEO SERIES - 6 Tape Series | [email protected] | Aviation Marketplace | 0 | November 2nd 06 04:12 PM |
Ancient Service Bulletin on Converting Continental A-Series and C-Series Engines to Higher Horsepower: 65 to 75HP, Etc. | jls | Home Built | 0 | February 21st 05 04:36 PM |
