Trailer fittings - which plastic?
Old January 26th 15, 10:59 AM posted to rec.aviation.soaring
Ben Coleman
Default Trailer fittings - which plastic?
Hi all,
I am refurbishing a Komet trailer. The wing fittings have plastic rods to hold the spar end - I have always assumed this is "delrin" but of course when I look into what is available there are a zillion plastic types! What is the best choice? Or does it not really matter as long as it's softer than the spar bushings?
Thanks Ben
Old January 26th 15, 12:51 PM posted to rec.aviation.soaring
On Monday, January 26, 2015 at 5:59:25 AM UTC-5, Ben Coleman wrote:
Hi all,
Thanks Ben
I does not matter much. I make pins like that out of PVC rod because it is readily available, machines easily and has no negative properties for this application.
I just made a set for a Komet.
UH
Old January 26th 15, 02:21 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Speaking of a Komet trailer, I have an LS-3a in a Komet and the factory set up the wing dolly's to use the forward spar pin. This is a very unstable situation and the wing really wants to flop over when running it in or out of the trailer. I set the right wing on the wing dolly using the rear spar pin and the wing skin was touching the dolly (believe this is why they opted to use the forward spar pin). Don't see why I couldn't grind / cut the offending corner off the wing dolly, so that both wings could use the rear spar fittings. The stops would have to be re-set and top capture fittings re-set (checked). Probably get inside the trailer with a flash lite and then ask Pat to close the trailer....................I wouldn't attempt this unless you have a very stable relationship with the wife!
:) JJ
Old January 29th 15, 01:59 AM posted to rec.aviation.soaring
Ben Coleman
Thanks.
Hi all,
Thanks Ben
UH
Old January 29th 15, 04:51 AM posted to rec.aviation.soaring
Bill T
Our LS4 in a Komet trailer uses the rear spar pin (closest to wing) for the wing dolly.
Bill T
Comet to Cobra Trailer fittings conversion Gregg Leslie[_2_] Soaring 1 November 10th 12 07:49 PM
Comet to Cobra Trailer fittings conversion Gregg Leslie[_2_] Soaring 0 November 10th 12 12:33 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 09:51 PM
Trailer fittings and carpetting [email protected] Soaring 3 September 4th 09 03:27 AM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 03:21 PM
