Ventus B, Discus ect aileron connecting rod/slide lube
Old February 3rd 15, 07:10 AM posted to rec.aviation.soaring
Alexander Swagemakers[_2_]
Default Ventus B, Discus ect aileron connecting rod/slide lube
I would suggest not lubricating any kind of plastic bearing. Dust will stick to the lubricant and increase wear. Depending on the lubricant used the plastic may also start swelling. You can easily make thinks a lot worse by wrong lubrication. Keeping the bearing clean and the pushroad polished is probably the best approach. If you want to use a lubricant then maybe a thin film of something on a silicon or teflon basis would be good. In any case make sure the lube is compatible to the sleeve material and will not cause swelling.
Discus Aileron Seals Peter F[_2_] Soaring 8 August 20th 13 05:07 PM
left aileron for Discus CS wanted [email protected] Soaring 0 September 28th 12 01:31 AM
New Ventus 2 and Discus Winglets - M&H Alpha Eight Soaring 11 February 21st 12 04:41 PM
Looking for Left Outer Aileron for Ventus C Bob Gibbons[_2_] Soaring 0 June 30th 09 02:12 AM
Ventus 1 - anyone have experience w/o aileron centering spring? Gary Emerson Soaring 0 November 1st 08 02:36 PM
