XC soar data issues
Old February 3rd 15, 04:56 PM posted to rec.aviation.soaring
HGXC[_2_]
Default XC soar data issues
On Tuesday, February 3, 2015 at 11:20:32 AM UTC-5, Dan Marotta wrote:
I originally used the serial port of my CAI 302 for power but I
think that exceed the output capability of the 302 so I installed a
car 12v adaptor with a USB charger and a toggle switch to control
charging.* I also used a K6BT for the control/data connection to the
302.* The K6BT is wired directly to my DC bus for its power source.*
I have a friend who uses an IOIO and he's happy with that, so it's
really up to you.
Depending on your computer/recorder, your log file can be downloaded
to your streak to carry home.* Note that the proprietary connector
on the side of the Streak is its weak point and will fail with
multiple connect/disconnect cycles.* To get around that, I've
permanently installed the cable in my streak and I download files to
my smart phone (bluetooth).
Now that I've just installed a ClearNav vario, I can simply pull the
USB stick out of the panel and take it home or next door to the FBO
to upload my flight trace.
On 2/3/2015 5:43 AM, HGXC wrote:
On Monday, February 2, 2015 at 6:56:24 PM UTC-5, HGXC wrote:
I have a dell streak and have downloaded the XC soar software. I am having issues having xc soar recognize the data files like maps airspace and waypoints. I can download these data files directly and I had to use file transfer from my pc.
Any ideas on what I am doing wrong.
Dennis
Well we are up and running...thanks all. Now how to connect this to battery for power and my lnav?
Dennis
Dan Marotta
So with a ioio board i could plug it into my cam model 20 gps and get connected and power from there? That's what i plug my compaq pda with glide nav today.
Dennis
Old February 3rd 15, 05:05 PM posted to rec.aviation.soaring
Luke Szczepaniak
charging. I also used a K6BT for the control/data connection to the
302. The K6BT is wired directly to my DC bus for its power source.
really up to you.
to your streak to carry home. Note that the proprietary connector
multiple connect/disconnect cycles. To get around that, I've
Dennis
Dennis
Dan Marotta
Dennis
Should be no problem. If you aren't interested in making your own IOIO
(i've made a few) you can purchase andrport, a neat little ioio based
device that supports two separate NMEA sources.
http://www.glidertools.com/products/androport/
With this you will only need to make cable to connect to your model 20
and provide 12v to the androport which will in turn supply 5v and nmea
data to the android device.. I helped a friend set this up and it went
smoothly.
Luke
Old February 3rd 15, 08:29 PM posted to rec.aviation.soaring
HGXC[_2_]
really up to you.
Dennis
Dennis
Dan Marotta
Dennis
smoothly.
Luke
I can't get that site to come up...says its still in development
Can you send me a different link...I am interested!
Thanks
Dennis
Old February 4th 15, 01:39 PM posted to rec.aviation.soaring
Luke Szczepaniak
I think they may be in maintenance mode - i am pretty sure they have
been around for a while. The site was up when i sent the link yesterday
I would check the main site occasionally.
Old February 4th 15, 06:48 PM posted to rec.aviation.soaring
HGXC[_2_]
Ok got it and he sent me a flyer on the board. Now will that allow me to plug serial cord into my cambridge gps model 20 (not the 302) and get 5v power and communicate to my Lnav which is already pluged in the cambridge?
Dennis
Old February 4th 15, 07:46 PM posted to rec.aviation.soaring
Luke Szczepaniak
Dennis
I am not familiar with model 20 or the lnav, maybe someone else can comment.
Luke
Fat boy wants to soar... toggles mcfarley Soaring 24 March 23rd 10 06:51 PM
XC-Soar [email protected] Soaring 4 January 26th 09 04:06 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
why do you soar? Mark James Boyd Soaring 27 October 21st 03 07:48 PM
