Any idea if this app uses a lot of data? That might be an issue for those with limited data phone plans.
Lou |
On Tuesday, February 3, 2015 at 1:52:49 PM UTC-7, MNLou wrote:
Any idea if this app uses a lot of data? That might be an issue for those with limited data phone plans. Lou The data sent is the content of your IGC file. It is just sent piece by piece. I would add 10-20% to cover data transmission overhead. The default position recording rate is a variable sample rate which is equivalent in data size to a 5 second sample rate. You can choose the data sample rate, from 1sec to 5mins. The bottom line is a typical selfie is going to use a lot more than a typical flight. Probably more than your longest ever flight. Alan |
On Tuesday, February 3, 2015 at 3:33:28 PM UTC-6, kiwiindenver wrote:
The bottom line is a typical selfie is going to use a lot more than a typical flight. Probably more than your longest ever flight. Alan Great response Alan! Thank you. I will be downloading the app this evening. Lou |
SeeYou Recoder - an Android app for glider pilots | [email protected] | Soaring | 7 | July 11th 12 07:16 PM |
Small glider logbook for Android phones | Tiny Titles | Soaring | 0 | July 28th 11 08:34 PM |
XCSoar for Android | Sean Fidler | Soaring | 6 | March 21st 11 05:50 PM |
Possible Android Tablet? | jsbrake[_2_] | Soaring | 5 | February 5th 11 07:57 PM |
Android App | Mike[_36_] | Soaring | 8 | July 14th 10 10:53 AM |
