Glider Down - Soaring Mag Feb 2015
Old February 4th 15, 10:05 PM posted to rec.aviation.soaring
son_of_flubber
Default Glider Down - Soaring Mag Feb 2015
The 'Glider Down' article in this month's soaring magazine was great. I hope that the new editor Eric Bick makes this sort of article routine.
Old February 5th 15, 03:24 AM posted to rec.aviation.soaring
BobW
Second! On both fronts.
And Serious Kudos to Jay Campbell for having the mindset to share his accident
with the rest of the U.S. soaring community. I hope he sees fit to learn every
lesson he can draw from the unhappy experience, and opts to continue with the
sport.
Bob W.
Old February 5th 15, 02:48 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Great new look to the mag, but the Libelle article missed the most significant achievement of the old girl. Ray Gimmey won the 1972 open Nationals flying a Libelle!
I too believe we should be reviewing our accidents as George Theylen did in Soaring for many years.
JJ
Old February 5th 15, 04:49 PM posted to rec.aviation.soaring
SoaringXCellence
JJ
There were a bunch of Libelle H301s flying in the '72 nationals. Mine, flown by my father Jack Bamberg, took 3rd.
Mike
Old February 6th 15, 03:08 AM posted to rec.aviation.soaring
I also commend Jay for sharing his unfortunate wave experience and turning it into an excellent Teaching Moment.
Old February 6th 15, 03:33 AM posted to rec.aviation.soaring
Mike the Strike
I've known of more than a couple of incidents involving inadvertent opening of spoilers that were not caught by the pilot and led to an accident or nearly so.
I was taught (by a German instructor) always to visually check spoilers when deploying them and again to check they were closed, something I have always done. I also only deploy spoilers when within safe distance of the field and almost never while flying cross-country. I remember a colleague who outlanded when he deployed his spoiler and the handle broke off, leaving them fully open!
Mike
Old February 6th 15, 04:39 AM posted to rec.aviation.soaring
Bill D
Mike
As long as we are discussion solutions to unintended open spoilers, why not adopt the airplane solution in the form of an annunciator panel on the glare-shield consisting of LED lights? A big red one would indicate unlocked open spoilers and a small green one indicating they are closed and locked. The idea could be extended to the usual red-yellow-green gear warning and even to unlatched canopies and tail dollies still on the tail-boom.
Panels are being packed with an almost unbelievable array of computerized instruments, why not add a row of simple LED lights that might eliminate a few accidents? We now have good batteries and very bright, efficient LED's so why not?
Old February 6th 15, 05:11 AM posted to rec.aviation.soaring
Mike the Strike
Bill: That's a brilliant idea. My Ventus already has an LED light array for flap position on top of the glare-shield - it would be trivial to add similar ones for spoilers and gear.
Mike
Old February 6th 15, 09:17 AM posted to rec.aviation.soaring
Jim White[_3_]
Mike
Just a thought....would it not be a good idea to fit the flap leds around
the asi in the appropriate positions?
Old February 6th 15, 10:34 AM posted to rec.aviation.soaring
Justin Craig[_3_]
Or look out at the wings?
Is adding additional information to an already busy panel not complicating
matters?
Is it not also encouraging one to look in and not out? Good look out should
be promoted.
openi=
or
nearly so.
=20
w=
al=
fi=
wh=
leaving
them fully open!
=20
Mike
not=
gla=
unlocked
locked.
and
i=
f=
LED's
so why not?
ChicagoLand Glider Council Seminar - Feb 21, 2015 Six-Seven Soaring 10 February 17th 15 02:52 PM
ASA 2015 Soaring Season Opener Waveguru Soaring 2 January 31st 15 07:02 PM
Soaring the Appalachians Seminar, 7-8 Feb 2015 [email protected] Soaring 1 January 13th 15 06:49 PM
2015 Region 7 Soaring Contest in Albert Lea, Minnesota Paul Remde Soaring 0 January 13th 15 05:48 PM
Glider rental for the 1st Pan-American Championships in April 2015 Sergio Bassi Soaring 0 October 23rd 14 10:16 PM
