One fairly consistant problem I have seen in a number of aluminum trailers, is a distortion near the front hinge on the top. It allows the top to shift forward and creates interference at the rear with hard closing and misalignment of the latches. The distortion appears right at the corner. I believe it occurs with the forward loading on the top coming from the rather strong gas struts over time.
Of the five aluminum Cobra trailers parked at the field, three have this problem. None of the fiber glass top trailers show a similar problem. Buzz Graves |
On Thursday, February 12, 2015 at 2:29:33 AM UTC-5, BG wrote:
One fairly consistant problem I have seen in a number of aluminum trailers, is a distortion near the front hinge on the top. It allows the top to shift forward and creates interference at the rear with hard closing and misalignment of the latches. The distortion appears right at the corner. I believe it occurs with the forward loading on the top coming from the rather strong gas struts over time. Of the five aluminum Cobra trailers parked at the field, three have this problem. None of the fiber glass top trailers show a similar problem. Buzz Graves Plenty of fiberglass tops have the same problem; actually any trailer produced prior ~ 2010 IIRC. Later trailers have a small block carrying loads from top's lower side-rail and pressing against front hinge plate. I designed a fix with Alfred and can post info if anyone is interested... Hope that helps, Best Regards, Dave |
On Thursday, 12 February 2015 07:17:26 UTC-7, Dave Nadler wrote:
On Thursday, February 12, 2015 at 2:29:33 AM UTC-5, BG wrote: One fairly consistant problem I have seen in a number of aluminum trailers, is a distortion near the front hinge on the top. It allows the top to shift forward and creates interference at the rear with hard closing and misalignment of the latches. The distortion appears right at the corner. I believe it occurs with the forward loading on the top coming from the rather strong gas struts over time. Of the five aluminum Cobra trailers parked at the field, three have this problem. None of the fiber glass top trailers show a similar problem. Buzz Graves Plenty of fiberglass tops have the same problem; actually any trailer produced prior ~ 2010 IIRC. Later trailers have a small block carrying loads from top's lower side-rail and pressing against front hinge plate. I designed a fix with Alfred and can post info if anyone is interested... Hope that helps, Best Regards, Dave Dave, please post the fix designed. I remember the discussion from a few years ago but know that I have a Cobra trailer again I am interested Ron Gleason |
On Thursday, February 12, 2015 at 9:36:57 AM UTC-5, Ron Gleason wrote:
On Thursday, 12 February 2015 07:17:26 UTC-7, Dave Nadler wrote: On Thursday, February 12, 2015 at 2:29:33 AM UTC-5, BG wrote: One fairly consistant problem I have seen in a number of aluminum trailers, is a distortion near the front hinge on the top. It allows the top to shift forward and creates interference at the rear with hard closing and misalignment of the latches. The distortion appears right at the corner. I believe it occurs with the forward loading on the top coming from the rather strong gas struts over time. Of the five aluminum Cobra trailers parked at the field, three have this problem. None of the fiber glass top trailers show a similar problem. Buzz Graves Plenty of fiberglass tops have the same problem; actually any trailer produced prior ~ 2010 IIRC. Later trailers have a small block carrying loads from top's lower side-rail and pressing against front hinge plate. I designed a fix with Alfred and can post info if anyone is interested... Hope that helps, Best Regards, Dave Dave, please post the fix designed. I remember the discussion from a few years ago but know that I have a Cobra trailer again I am interested Ron Gleason I just had my 30 year old cobra trailer's flip door fixed. I replaced the gas struts and sure enough it cause the top to shift even more then it already had. I had them weld braces in the front corners and repainted it. All the riding over bumpy roads over the years works the aluminum because it has insufficient bracing. Dennis |
Please post, I am looking for a fix
Buzz |
Yes Dave please post all info you have on this!
I am also in need of this fix. |
On Friday, February 13, 2015 at 12:17:26 PM UTC, joesimmers wrote:
Yes Dave please post all info you have on this! I am also in need of this fix. I don't know whether Dave's fix is the same as Steve Koerner's fix that was linked here a few years ago but, just in case, here is the link to the latter: https://app.box.com/shared/9dvnt7qgs8 John Galloway |
On Friday, February 13, 2015 at 12:03:28 PM UTC-5, wrote:
I don't know whether Dave's fix is the same as Steve Koerner's fix that was linked here a few years ago but, just in case, here is the link to the latter: https://app.box.com/shared/9dvnt7qgs8 John Galloway That's a different problem (hinge and top attachment). I will try dig out the info on the top corner problem and post later... Hope that helps, Best Regards, Dave |
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
looking for used Cobra trailer | Brad[_2_] | Soaring | 3 | July 1st 11 02:58 AM |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
Cobra Trailer | [email protected] | Soaring | 22 | December 7th 06 11:38 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM |
