This article covers most of the basics:
http://soaringcafe.com/2011/01/desig...ion-sailplane/ Assuming you want to stay within the constraints of EASA CS22, wing loading can't exceed 60 kg/m2 much. A higher aspect ratio not only means a higher L/D max, it also means that L/D max occurs at lower and lower relative speeds. In other words, going from AR=32 to AR=57, L/D max might go up substantially but fully ballasted, performance at 70 kts barely changes. For many long-ears L/D max already occurs at speeds one will only fly while thermalling. |
WGC Open Class | Richard Walters | Soaring | 1 | August 12th 12 05:14 PM |
Should SSA Regional contests allow water in FAI class...15, 18, 20,Open class? | Sean Fidler | Soaring | 25 | December 16th 11 02:14 PM |
Open Class Nationals | [email protected] | Soaring | 6 | July 12th 05 05:05 PM |
DAY 4 U.S. Open Class Nationals | [email protected] | Soaring | 3 | July 3rd 05 03:24 PM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
