Best places for a soaring pilot to retire?
Old February 17th 15, 07:51 AM posted to rec.aviation.soaring
Fox Two[_2_]
Default Best places for a soaring pilot to retire?
You can reach me at:
c dot j dot fleming at hotmail dot com
FYI, I fly from Fayence, about an hour west of Nice. We have a few Duo Discus available if you're interested!
Chris
Old February 17th 15, 09:10 PM posted to rec.aviation.soaring
Jonathan St. Cloud
HI Chris. I was wondering if you could write a bit about the soaring in France (how how long the season is, how strong the thermals, many glider ports and variety of terrain, is there good wave, ridge, good xc options... etc..) What is it like living France... I know none of the above but somehow I find myself jealous
Old February 18th 15, 08:07 AM posted to rec.aviation.soaring
Le mardi 17 février 2015 22:10:49 UTC+1, Jonathan St. Cloud a écrit*:
HI Chris. I was wondering if you could write a bit about the soaring in France (how how long the season is, how strong the thermals, many glider ports and variety of terrain, is there good wave, ridge, good xc options... etc.) What is it like living France... I know none of the above but somehow I find myself jealous
I've been flying in this region for the last 20 years in la Motte du Caire, Seyne-les-Alpes and since a couple of years in Fayence (Chris, I'm the nuthole who had blocked your trailer with my rigged Ventus in the morning something like two years ago...).
Season goes typically from March to end of September. Two large clubs (Fayence and Vinon) have all-year-round activity, but winter thermals are fairly week. Variety of terrain is almost flat land to the south (Vinon) to... well anywhere you want to go in the Alps. Highest summit would be Mt Blanc about 250 km north of Fayence with 4800m.
Right (10 km) North of Fayence start the French Sea Alps, which is a mountain range about 100 km with tops in the 2000-2500m, giving to the high alpine region with 3000-4000m tops.
Thermal strength is anything from 1 to 10 knots (rarely above), and on a real good day you don't stop for anything below 6 knots. Ceilings are 3000-4000 m on good days, which means that you often fly the ridges to climb, and you have to manage mountain passes. Going from Fayence to Switzerland involves passing several passes into different meterological regions, with 2 mountain pass at 300 m. An out-and-return from Fayence to the Furka Pass is 800 km and takes you along the most spectacular landscape in Europe.
Outlanding field have to be carefully managed as valleys are deep and narrow. However, there is are catalogues of referenced fields for France, Switzerland and Austria, with each field presented with photos, GPS reference, elevation, do's and don'ts. So although sometimes the next field may be 50 km away, you can fly safely and most of the time, there are several options.
There are frequently wave days, notably with strong Northern wind (called "Mistral") which is a stable meterological situation, often lasting for a couple of days. Klaus Ohlmann did an out-and-return from Serres to Wiener Neustadt some years ago, which is 1400 km. There is also some wave with strong Western or Southern wind preceeding a frontal system (and often not even holding for the whole day). During wave conditions, outlanding is better restricted to airfields.
Living in France... I've been living in Grenoble (roughly 100 km north of Provence) for a good 5 years, but that's been almost 20 years ago (now I live in the French part of Switzerland - mountains start at 3000 m right away ;-)), but I did like it. Living on the French Riviera is certainly a much sweeter plan, but you probably want to flee the crowds moving down from Paris durng July/August. But that's the time you want to spend in the air anyways ;-) I have a very good friend living close to Hyères, and he spends summers on the airfiled, and winters going sailing.
Bert
TW
Old February 18th 15, 08:14 AM posted to rec.aviation.soaring
Le mercredi 18 février 2015 09:07:44 UTC+1, a écrit*:
... different meterological regions, with 2 mountain pass at 300 m...
Bert
TW
Oups, that would be 3000 m.
And John, should you be jealous?
Certainly so. :-D
Bert
TW
Old February 18th 15, 07:56 PM posted to rec.aviation.soaring
Fox Two[_2_]
That was a good summary from Bert (no worries about blocking me with your Ventus, I managed!) about soaring in the French Alps.
Jonathan, there are 17 clubs in just the PACA region alone (southeastern most part of France), with most airports offering launches to those who make unintended visits. Here's a link to who's whe
http://ffvv.org/debutant-edito/annua...83_06_04_05_84
As Bert said, thermal season in the Alps runs from March to September, but today we had lift to 2500 meters and completed 250 km tasks. Not bad for February 18th. We also have a nice wave season from December through March. We have a wave window up to FL235 at Fayence. Last year I was still climbing at 14 knots passing FL230, and I had to open the spoilers and find the "down side" of the wave to get down.
March can be magical with both strong waves and strong thermals. We can have weak waves at any time though, even in July, and for those who know how to exploit them can increase their glide ratios to infinity.
What I love about the Alps, though, is the technique of flying along mountain faces all day long, nursing the anabatic lift, but not circling in it unless you need to clear a high pass. You can get some amazing glide ratios and cross-country speeds if you can resist the urge to stay high!
Another poster commented on the difficulty of moving internationally. Yes, by definition it is a bigger hassle than staying domestically. Is it impossible? No. Why did I do it? Because it was worth it! And I would do it all over again.
Chris
Old February 19th 15, 01:04 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Thank you for sharing the French conditions. How long did it take you to learn French? Sounds absolutely wonderful. I spent a month in Paris during 2003 and fell in love with everything French!
Old February 19th 15, 07:38 AM posted to rec.aviation.soaring
Le jeudi 19 février 2015 02:04:29 UTC+1, Jonathan St. Cloud a écrit*:
A crash course for a month with 4h per day will make you see good progress. Local female implication would be a real boooster :-D
TW
Mar 27, 2010 Utah Soaring Seminars and Pilot Get Together Bruno[_2_] Soaring 0 February 26th 10 12:15 AM
Senior Soaring Pilot ZASoars Soaring 0 October 3rd 04 03:43 AM
Senior Soaring pilot ZASoars Soaring 0 October 3rd 04 03:38 AM
World Champion Soaring Pilot To Speak at Sky Soaring John DeRosa Sky Soaring Chicago IL Soaring 0 May 14th 04 09:02 PM
OT... Need pilot to fly aircraft to Crazy Creek Soaring area Steve / Sperry Soaring 1 May 10th 04 01:11 AM
