Towing with a TDI
Old February 18th 15, 01:41 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Towing with a TDI
On Tuesday, February 17, 2015 at 3:50:43 PM UTC-6, vontresc wrote:
Maybe Steve Leonard has a spare "Stalker Van" he could part with ;-)
Peter
Maybe he does. Do you want the optional "Smoke Screen" for easy get-a-way?
Steve Leonard
Old February 18th 15, 03:57 AM posted to rec.aviation.soaring
Tony[_5_]
Peter
Steve Leonard
is the smoke screen really an option?
Old February 18th 15, 12:51 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
I did about 7500 miles towing trailers round europe last year behind a SWB
toyota land cruiser tdi and a VW passat TDi130 estate.
With the land cruiser you didnt notice you had anything on the back (even
with a Nimbus 4 in a cobra trailer). However fuel consumption was in the
low 20mpg and it was uncomfortable.
The Passat was great. Measured fuel consumption was 47mpg with a LS6/18 in
a tube trailer. Very comfortable and stable up to well in excess of the
legal lmit.
As said elsewhere the TDI engine characteristics are great for towing.
Loads of mid range torque that avoids constant gear changing that you get
with a similar size petrol engine.
The trick with stability with trailers is to get the weight distibution
corect. You want as much as possible over the axle(s) but with a sensible
amount on the draw bar. (not hundreds of pounds as I have seen advocated
here) If you put all the spare gubbins in the front and back of the trailer
you end up with a "dumbell" which is potentially unstable.
Nigel
Old February 18th 15, 02:44 PM posted to rec.aviation.soaring
legal lmit.
Nigel
Nigel, your mpg numbers are obviously based on British gallons which are kind of an inflated type of imperial gallons (too lazy to look it up right now). I think our mpg values would be 10-20% lower than your numbers. Why can't we all go metric???
Old February 18th 15, 03:19 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
And report in kilometers per liter?
Old February 18th 15, 04:42 PM posted to rec.aviation.soaring
Mike the Strike
"Inflated imperial gallons" - don't you mean deflated American gallons! I expect a pint of beer to be 20 fluid ounces, not 16!
Mike
Old February 18th 15, 10:48 PM posted to rec.aviation.soaring
Dan Marotta
On 2/18/2015 9:42 AM, Mike the Strike wrote:
snip
Mike
Best argument yet that I've heard for using any sort of Euro measurement!
Dan Marotta
Old February 18th 15, 03:29 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
SWB
(even
in
legal lmit.
get
sensible
advocated
trailer
Nigel
right
Why
47mpgUK =39mpg US = 6l/100km
My brain hurts now
Old February 18th 15, 04:02 PM posted to rec.aviation.soaring
Tango Eight
Apples / apples comparisons really aren't possible between US and anywhere else. Emissions regs are a bit different in USA, resulting in lower economy US for both diesel and gas. As well, USA gasoline is diluted with ethanol for political reasons (basically, Archer Daniels Midland corporation owns more of Congress than "We, the People") which further erodes gas economy.
T8
Old February 18th 15, 10:46 PM posted to rec.aviation.soaring
Dan Marotta
Why can't we all go metric? Because 10s of litres per 100 miles is a
silly measurement compared to miles per gallon. Same with knots
airspeed and lift/sink vs. km/hr and m/s. How about inches per teaspoon
for mileage?
legal lmit.
Nigel
Dan Marotta
Towing with a VW [email protected] Soaring 15 December 7th 07 08:20 AM
Air to ground towing 2 - after some R&R Dave Kearton Aviation Photos 3 June 10th 07 08:22 PM
Towing to the airport drano Home Built 3 August 25th 06 06:17 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
FAA says towing ULV's is OK? ken ward Soaring 4 September 30th 04 03:12 AM
