status of Delta Hawk diesel
Old January 18th 11, 12:30 AM posted to rec.aviation.homebuilt
CaveLamb
Default status of Delta Hawk diesel
Jim Logajan wrote:
jan olieslagers wrote:
The Delta Hawk has been VERY slow to come to the market, yet I have a
vague memory of the first samples being very close to release.
Anyone know the details, or of any flying apart from factory test/demo
planes?
TIA,
If you want an engine that runs on diesel, you HAVE to take a look at this
video:
http://www.youtube.com/watch?v=Yle0bNfmf0E
It's a turbine engine mounted on a CH-701. Kinda neat!
I suppose if ~90 HP isn't enough, you could always consider a twin design.
It said that 90 HP was turning a 68" prop!
Richard Lamb
email me:
web site:
www.home.earthlink.net/~cavelamb
Old January 18th 11, 08:06 AM posted to rec.aviation.homebuilt
bod43
planes?
TIA,
video:
Youtube text description says 12gph fuel use!!!
Old January 18th 11, 08:17 AM posted to rec.aviation.homebuilt
bod43
On Jan 17, 9:19*pm, Tom De Moor
says...
Aero-diesels impose from the start a kind of supercharger, adding
complexity, weight and more things to go wrong.
Hmm, well a 2-stroke like the delta-hawk does.
On the other hand on the Deltahawk there are no -
magnetos, spark plugs, leads
valves, camshafts, followers, pushrods, rockers
cylinder head gaskets (head integral with cylinder)
Engine has *no* need for an electrical supply to run.
I have followed the development for a while and very much like
the concepts behind the deltahawk.
Some makes add also a PSRU, once again adding weight, extra maintenance
and cost.
Engine speed is such that no PSRU is required.
The
other problem is that fuel pumps and injector systems used on diesel engines
usually will not work using jet fuel, which is the fuel these engines are
normally going to be using.
Deltahawk designed from outset for Jet fuel.
Of course, the largest problem is having the money it takes to develop an
engine and get it to market. *Costs can be enormous.
DH are still there. They claim that "Experimental" engines
are available now with certification Real Soon
As I said, I like the options they have chosen for their
clean sheet design. There seems every prospect that they
will be safe, robust and economical if the fuel tax in any
particular jurisdiction does not rule that out.
Old January 18th 11, 08:19 AM posted to rec.aviation.homebuilt
Morgans[_2_]
A 3 bladed 68 inch prop, burning that much fuel even at turbine inefficiency
sounds like a buttload more than 90 HP, to me!
Jim in NC
Old January 18th 11, 10:04 AM posted to rec.aviation.homebuilt
CaveLamb
inefficiency sounds like a buttload more than 90 HP, to me!
Yup.
I suspect that's 90 HP at the shaft - BEFORE the gearbox.
BTW, there is quite a bit of information about this setup on the web.
Velly intelesting...
Richard Lamb
email me:
web site:
Old February 19th 15, 09:40 AM posted to rec.aviation.homebuilt
planes?
TIA,
I have been watching them over here avgas europe 2.5 euros a litre Jet A1 1 euro wish continentals ran on diesel with magneto's forget the efficiency of diesel its just cheaper by a country mile,dont worry by the time Deltahawk come out with a for sale product I will have developed a nuclear fusion reactor turbine drive that runs on water and weighs 50 kilos
zoche diesel status and specs? Ed Wischmeyer Home Built 5 June 21st 04 02:24 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
