Here's the skinny on OO....so just about (but not necessarily) every SSA member
A: In the United States, the SSA has established the following requirements for a person to act as an Official Observer (OO) for any FAI Badge or Record flight or SSA State Record or Awards flight: Must hold at least an SSA B Badge or higher SSA Badge (C or Bronze Badge), or a leg of an FAI Badge (e.g., Silver Altitude) or completed FAI Silver, Gold or Diamond Badge. Must have a working knowledge of the FAI Sporting Code as it pertains to gliders (Section 3) including Annex C which is a guide to the Code. Must be an SSA Member. An Airport Manager may also act as an Official Observer On Saturday, February 21, 2015 at 7:44:53 PM UTC-5, Dan Marotta wrote: IIRC, unless something has changed, not just any SSA member is qualified as an observer. I believe the observer has to at least hold a badge leg. Airport managers also qualify and, perhaps, an FBO. Just be sure to get it right. It's a bummer to have a good flight disqualified on a technicality but the technicalities are part of the process. Don't cut corners. Good luck! On 2/21/2015 5:31 PM, Cookie wrote: Observer: Just ask around! Any SSA member should be qualified, and willing. You do all the "grunt" work and get the forms and fill them out properly...so the observer needs only to "supervise" and sign. Don't become a "pest" Flight recorder: 1) Just ask! Somebody will probably have something they can lend you. 2)Or... Most pilots join some sort of glider club. Most clubs have such equipment available to members.. 3)Some commercial glider operators offer "rental" of flight recorders for a "small fee" 4)If you wish to use a simple old fashioned mechanical baragraph, I bet somebody would give you one for the asking....Back in the day, they were in the range of $400 and up! Nowadays they are used for Christmas tree decorations, door stops, and to start nostalgic conversations. No actual monetary value....My club has 6 of 'em sitting in the closet in the equipment shed! 5) Consider buying your own equipment....this is something you may find useful for years to come. Some used ones come up now and then...The "fly with CE" is a good deal...maybe colibri II....etc? Cookie On Saturday, February 21, 2015 at 5:53:54 PM UTC-5, Bob Pasker wrote: I would like to attempt the duration and altitude silver badge. how do I go about finding an observer willing to work with me? how do I borrow/rent an appropriate flight data recorder? thanks, bob -- Dan Marotta |
I'll second the use of the FlywithCE FR300. I purchased one for this past season and was able to obtain my Silver Badge with it. It does require you to use the associated Logbook to download the .igc's from the recorder. Naturally the Logbook program is only available for a Windows based computer.. This did force me to finally install Bootcamp and Windows 7 on my iMac. But use of the Recorder is extremely easy. I just turn it on about 10 minutes or so before takeoff and turn it off a couple of minutes after landing and that's it.
fly with ce silver badge question | Bob Cook[_2_] | Soaring | 4 | August 20th 13 04:37 PM |
fly with ce silver badge question | Bob Cook[_2_] | Soaring | 0 | August 20th 13 02:47 AM |
Silver Badge! | [email protected] | Soaring | 17 | November 24th 08 03:12 AM |
Silver Badge Fun (?) | Mark Zivley | Soaring | 43 | July 14th 03 07:52 PM |
Silver Badge Fun (?) - real challenges? | Nyal Williams | Soaring | 0 | July 11th 03 04:45 PM |
