FLARM ethics
Old February 23rd 15, 10:06 PM posted to rec.aviation.soaring
Colin Wray[_3_]
Default FLARM ethics
On Monday, 23 February 2015 17:53:17 UTC, pcool wrote:
I am afraid I posted to the wrong audience, because you dont even know that
most of flarm units in europe do not have the capability to be reprogrammed
with a memory card.
You have to use a PC with a rs232 serial cable, to connect to the RJ45 plug
of the Flarm unit.
Most people do not even know what the heck this means.
I fear these people that may fly around for weeks, or months, with a
non-working flarm.
The collision avoidance works on the principle of cooperation, as with Flarm
here.
If you dont have a working unit, my working unit will not work too.
If I crash against a glider and the pilot says "my flarm did not say
anything.." and we discover it was not updated, you bet your home, wife and
kids that I shall sue the swiss company all the way. What they are doing is
criminal.
There are only two reasons why we dont have the firmware now, with a
blackout pending in 45 days.
A) Firmware is not yet ready and debugged. If this is the case, since we are
talking of SAFETY, the best thing to do is to postpone by some months the
entire matter.
B) Firmware is ready, but flarm is dealing with its Tracking server and
currently it is negotiating with the people of OGN and their network of
receive stations round the world that will be soon obscured at the end of
march. Yes, this is the missing point. Nothing to do with safety.
But let's calm down please, no reason to argue..
On Sunday, February 22, 2015 at 2:24:44 PM UTC-6, Mike Schumann wrote:
On Sunday, February 22, 2015 at 12:36:15 PM UTC-5, Andy Blackburn wrote:
Any device used for collision avoidance will have some of its critical
capabilities dependent on both aircraft in a potential collision
situation having the same algorithms on board or chaos (or worse) might
ensue. Making the update mandatory and taking non-updated units out of
service is the only way to ensure safe and reliable performance of the
entire system.
You might quibble a bit about the lead time, but updating the firmware
is really not very complicated. I tried a different firmware version (or
different config file) practically every day at the 15m nationals last
year as I was trying to work out a PCAS problem and a interface issue
with my LX 9000. All you need is the firmware and a memory stick.
It's not that hard.
It will all work out in the end.
Remain calm.
9B
It is NOT impossible to design system upgrades so that they are backward
compatible with older units that are still in use. It is probably much
more convenient for FLARM to use this approach so they don't need to deal
with the complexity of having multiple different device versions that need
to talk to each other. These kind of shortcuts make one question whether
FLARM really has the potential to be a VERY niche product for a small
subset of the aviation market.
Couple that with POWERFLARM's inability to see UAT equipped ADS-B OUT
equipped aircraft, either directly or via TIS-B retransmission from an
ADS-B ground station, raises some big questions on whether or not they
have really thought thru the whole collision avoidance picture in the US,
where the threat is not just other gliders, but also GA and airline
traffic.
I wish the Messr. Schumann and Suppards would just join hands and walk away,
far away from this forum. Maybe they can entertain each other with their
nonsense.
Anyone with a non-updated Flarm will be well aware that it is not working because there will be (unit-dependent) positive indications of the problem.
Old February 25th 15, 01:18 AM posted to rec.aviation.soaring
pcool
"Colin Wray" wrote in message
Precisely! And those with updated Flarm will not know that the other are not
working.
Here's the song about the brave pilot with its updated and working Flarm,
that cannot "see" the others.
Where have all the gliders gone,
long time passing?
long time ago?
Where have all the Flarms gone?!?
Need to update, every one!
When will they ever learn,
when will they ever learn?
(Pete Seeger)
Old February 25th 15, 04:05 PM posted to rec.aviation.soaring
Luke Szczepaniak
On 02/25/2015 10:31 AM, John Galloway wrote:
You can still look out the window from time to time
Exactly, FLARM is an aide if you NEED it you're doing it wrong...
Old February 25th 15, 06:21 PM posted to rec.aviation.soaring
kirk.stant
On Wednesday, February 25, 2015 at 10:05:58 AM UTC-6, Luke Szczepaniak wrote:
Well, no, not always - more likely you NEED it if SOMEONE ELSE is doing it wrong!
For example, someone entering you thermal where you can't see him, and not clearing his flight path so he hits you - you can do everything right and still be blindsided.
Or, in the case of PowerFLARM, a powerplane blasting through your thermal or glider field airspace at pattern altitude. Sure are a lot of nice pretty screens to look at in modern planes, why look outside? And if there isn't 10,000ft of concrete and a control zone around it, there couldn't be an active airfield in that big grass field, after all....
Kirk
66
Flarm to MIO 400 [email protected] Soaring 1 January 23rd 15 06:05 PM
Flarm v5 Kevin Neave[_2_] Soaring 5 February 23rd 11 01:35 PM
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
