FLARM ethics
Old February 25th 15, 01:18 AM posted to rec.aviation.soaring
pcool
Default FLARM ethics
"Colin Wray" wrote in message
Anyone with a non-updated Flarm will be well aware that it is not working
because there will be (unit-dependent) positive indications of the problem.
Precisely! And those with updated Flarm will not know that the other are not
working.
Here's the song about the brave pilot with its updated and working Flarm,
that cannot "see" the others.
Where have all the gliders gone,
long time passing?
long time ago?
Where have all the Flarms gone?!?
Need to update, every one!
When will they ever learn,
when will they ever learn?
(Pete Seeger)
Old February 25th 15, 04:05 PM posted to rec.aviation.soaring
Luke Szczepaniak
On 02/25/2015 10:31 AM, John Galloway wrote:
You can still look out the window from time to time
Exactly, FLARM is an aide if you NEED it you're doing it wrong...
Old February 25th 15, 06:21 PM posted to rec.aviation.soaring
kirk.stant
On Wednesday, February 25, 2015 at 10:05:58 AM UTC-6, Luke Szczepaniak wrote:
Well, no, not always - more likely you NEED it if SOMEONE ELSE is doing it wrong!
For example, someone entering you thermal where you can't see him, and not clearing his flight path so he hits you - you can do everything right and still be blindsided.
Or, in the case of PowerFLARM, a powerplane blasting through your thermal or glider field airspace at pattern altitude. Sure are a lot of nice pretty screens to look at in modern planes, why look outside? And if there isn't 10,000ft of concrete and a control zone around it, there couldn't be an active airfield in that big grass field, after all....
Kirk
66
Flarm to MIO 400 [email protected] Soaring 1 January 23rd 15 06:05 PM
Flarm v5 Kevin Neave[_2_] Soaring 5 February 23rd 11 01:35 PM
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
