CNC Waterjet cutting instrument holes
Old February 26th 15, 09:27 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default CNC Waterjet cutting instrument holes
If you're unlucky, count on delaminations extending up to 1/3rd of an inch extending inboard. A good shop can put a soft material underneath to prevent delam, but it'll for sure require a few test runs, typically initial pressure is way too high.
A glass plate twice as thick underneath will certainly be adequate to solve any delaminations issues once they get the pressure right.
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 02:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 09:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Cutting shirttails??? Larry Dighera Soaring 11 September 3rd 03 03:34 PM
