On Thursday, February 26, 2015 at 4:06:54 PM UTC-5, Dan Marotta wrote:
It looks like this will fit the bill for me:* http://www.bioennopower.com/products...ery-pvc-pack.* It's a 12v 12 Ah soft pack with BMC and charger.* It appears it will slide right into my tig welded covered aluminum box where it will be padded with foam and secure from any stresses. It will be a simple matter to pull it out and take it home for charging.* I'll simply reload the (mostly) dead lead batteries back into the tail box for weight and balance purposes.* They won't be connected any more. On 2/26/2015 10:13 AM, Dan Marotta wrote: Thanks to all. It looks like NiMH batteries are out of the question for me.* I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance.* I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box.* The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search.* I could also build up a pack for a separate box which I've installed behind the seat back.* Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome.* I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta -- Dan Marotta Hi Dan, Even if you're only using the old LA batteries for ballast (in the tail)..... I would NOT recommend it. LA (Lead Acid) batteries will suffer from "plate sulfation", basically the "battery form of rust". This causes the battery plates to swell, sometimes a LOT. This can cause the pack to wedge itself into a fixed compartment as well as crack the case letting out the small amount of electrolyte contained within to go "where ever it wants" (basically down.... attacking anything,like steel..... "control cables/rods anyone?"). Take this info from an "Ex UPS battery monitoring person" with ~15 years in the industry. I have seen batteries explode/crack cases more than once. You want weight, get lead bricks, please DON'T use old LA batteries.......... UmmmmK?! ;-) |
Thanks for that great advice, Charlie! I will find lead bricks or shot
which I can load into the box. Bricks or sheet will be better, of course. On 2/26/2015 2:34 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Thursday, February 26, 2015 at 4:06:54 PM UTC-5, Dan Marotta wrote: It looks like this will fit the bill for me: http://www.bioennopower.com/products...ttery-pvc-pack. It's a 12v 12 Ah soft pack with BMC and charger. It appears it will slide right into my tig welded covered aluminum box where it will be padded with foam and secure from any stresses. It will be a simple matter to pull it out and take it home for charging. I'll simply reload the (mostly) dead lead batteries back into the tail box for weight and balance purposes. They won't be connected any more. On 2/26/2015 10:13 AM, Dan Marotta wrote: Thanks to all. It looks like NiMH batteries are out of the question for me. I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance. I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box. The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search. I could also build up a pack for a separate box which I've installed behind the seat back. Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome. I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta -- Dan Marotta Hi Dan, Even if you're only using the old LA batteries for ballast (in the tail).... I would NOT recommend it. LA (Lead Acid) batteries will suffer from "plate sulfation", basically the "battery form of rust". This causes the battery plates to swell, sometimes a LOT. This can cause the pack to wedge itself into a fixed compartment as well as crack the case letting out the small amount of electrolyte contained within to go "where ever it wants" (basically down.... attacking anything,like steel..... "control cables/rods anyone?"). Take this info from an "Ex UPS battery monitoring person" with ~15 years in the industry. I have seen batteries explode/crack cases more than once. You want weight, get lead bricks, please DON'T use old LA batteries......... UmmmmK?! ;-) -- Dan Marotta |
On Thursday, February 26, 2015 at 5:23:56 PM UTC-5, Dan Marotta wrote:
Thanks for that great advice, Charlie!* I will find lead bricks or shot which I can load into the box.* Bricks or sheet will be better, of course. I like these shot bags. Mix-n-match to get the weight that you want. Easy to swap out if you have someone heavier flying the ship. http://amzn.com/B0034ZECX4 |
Thanks for that great advice, Charlie!* I will find lead bricks or shot which I can load into the box.* Bricks or sheet will be better, of course. On 2/26/2015 2:34 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Thursday, February 26, 2015 at 4:06:54 PM UTC-5, Dan Marotta wrote: It looks like this will fit the bill for me:* http://www.bioennopower.com/products...ery-pvc-pack.* It's a 12v 12 Ah soft pack with BMC and charger.* It appears it will slide right into my tig welded covered aluminum box where it will be padded with foam and secure from any stresses. It will be a simple matter to pull it out and take it home for charging.* I'll simply reload the (mostly) dead lead batteries back into the tail box for weight and balance purposes.* They won't be connected any more. On 2/26/2015 10:13 AM, Dan Marotta wrote: Thanks to all. It looks like NiMH batteries are out of the question for me.* I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance.* I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box.* The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search.* I could also build up a pack for a separate box which I've installed behind the seat back.* Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome.* I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta -- Dan Marotta Hi Dan, Even if you're only using the old LA batteries for ballast (in the tail)..... I would NOT recommend it. LA (Lead Acid) batteries will suffer from "plate sulfation", basically the "battery form of rust". This causes the battery plates to swell, sometimes a LOT. This can cause the pack to wedge itself into a fixed compartment as well as crack the case letting out the small amount of electrolyte contained within to go "where ever it wants" (basically down.... attacking anything,like steel..... "control cables/rods anyone?"). Take this info from an "Ex UPS battery monitoring person" with ~15 years in the industry. I have seen batteries explode/crack cases more than once. You want weight, get lead bricks, please DON'T use old LA batteries.......... UmmmmK?! ;-) -- Dan Marotta NP, glad to add something worthwhile. ;-) |
Been shopping for lead for the past couple of hours and finally settled
on lead ingots. I've ordered 10 pounds and, if they don't simply slip into the battery box, they can be easily cut to fit. I'll be replacing 6 lb of batteries and moving the dry CG aft from 73% to 79%. I have enough capacity in the tail ballast tank to move it further aft as I like. The shot bags looked nice, but their form factor would not fit into the box which is very long and thin. I also considered lead shot which would have required me to line the battery box with aluminum foil and/or plastic wrap, pour in the shot, and then pour in epoxy to stabilize the load. The walls of the battery box are thin fiberglass and I would not have wanted any flexing to release shot into the lower fin area. All's well now - just waiting for Christmas to arrive! On 2/26/2015 8:22 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Thursday, February 26, 2015 at 5:23:56 PM UTC-5, Dan Marotta wrote: Thanks for that great advice, Charlie! I will find lead bricks or shot which I can load into the box. Bricks or sheet will be better, of course. On 2/26/2015 2:34 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Thursday, February 26, 2015 at 4:06:54 PM UTC-5, Dan Marotta wrote: It looks like this will fit the bill for me: http://www.bioennopower.com/products...ttery-pvc-pack. It's a 12v 12 Ah soft pack with BMC and charger. It appears it will slide right into my tig welded covered aluminum box where it will be padded with foam and secure from any stresses. It will be a simple matter to pull it out and take it home for charging. I'll simply reload the (mostly) dead lead batteries back into the tail box for weight and balance purposes. They won't be connected any more. On 2/26/2015 10:13 AM, Dan Marotta wrote: Thanks to all. It looks like NiMH batteries are out of the question for me. I have a 10 Ah LiFePO4 drop-in replacement as my main battery and am very happy with its performance. I'm looking for LiFePO4 cells (and BMS) for protection that can fit in my tail battery box. The dimensions of the drop-in box a Length = 58 cm Width = 3.5 cm Height = 6.5 cm No luck so far, but I'm continuing the search. I could also build up a pack for a separate box which I've installed behind the seat back. Its dimensions a Length = 36 cm Width = 4.8 cm Height = 10.8 cm Any suggestions would be most welcome. I've been searching the net, but nothing yet satisfies my specific needs. Dan On 2/26/2015 8:16 AM, Pierre Vav wrote: Hi, I have a pack of 11 9ah Nimh 1,2 v as a backup battery in the tail of my Lak17. They have the same format as alkaline D cells. I use a RC charger that automatically detects the right number of elements. At end of charge, voltage is arount 16,2 volts, but drops quickly to under 16. Also cable length drops voltage to something usable by instruments (15v). As it is a backup battery, I use it after the main 9ah pb is lowered down, so voltage is ok. I never had any problems with these batteries. But they are old now, and i plan to replace them with lifepo4. also nimh auto discharge force me to derig the tail very often. With Lifepo4, If I do not use the backup, no need to derig. -- Dan Marotta -- Dan Marotta Hi Dan, Even if you're only using the old LA batteries for ballast (in the tail).... I would NOT recommend it. LA (Lead Acid) batteries will suffer from "plate sulfation", basically the "battery form of rust". This causes the battery plates to swell, sometimes a LOT. This can cause the pack to wedge itself into a fixed compartment as well as crack the case letting out the small amount of electrolyte contained within to go "where ever it wants" (basically down.... attacking anything,like steel..... "control cables/rods anyone?"). Take this info from an "Ex UPS battery monitoring person" with ~15 years in the industry. I have seen batteries explode/crack cases more than once. You want weight, get lead bricks, please DON'T use old LA batteries......... UmmmmK?! ;-) -- Dan Marotta NP, glad to add something worthwhile. ;-) -- Dan Marotta |
Hey Dan -
Why not just use water for tail ballast and not have so much weight up high? Possibly a freezing problem at altitude? |
On Saturday, February 28, 2015 at 6:10:30 PM UTC-5, MNLou wrote:
Hey Dan - Why not just use water for tail ballast and not have so much weight up high? Possibly a freezing problem at altitude? Water can be good to offset the balance when dumping wing ballast..... If he is looking at "static balance" (my choice of words).... he is looking at fixed ballast for the "normal pilot" (normal is a relative term here.... if you're a pilot, lots of peeps think we're abnormal.... sigh). Tail water ballast can be useful when dumping wing water ballast creates a CG issue. Just my $0.02US........ |
Exactly right, Charlie!
I've chosen to add an extra 4 lb of lead to the tail battery box because, with dry wings and tail, my current CG is at 71% aft and that requires most of my aft trim capability, full aft trim for thermalling below about 50 KIAS. The extra 4 lb moves the CG back to 79% aft which should give me one or two notches on the trimmer and should be just fine during the winter months. In the summer, I can supplement the tail weight with the tail tank to move the CG back into the 90s. According to my W&B spreadsheet, I can trim to 92% aft at gross weight. That satisfies me. On 2/28/2015 4:41 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Saturday, February 28, 2015 at 6:10:30 PM UTC-5, MNLou wrote: Hey Dan - Why not just use water for tail ballast and not have so much weight up high? Possibly a freezing problem at altitude? Water can be good to offset the balance when dumping wing ballast..... If he is looking at "static balance" (my choice of words).... he is looking at fixed ballast for the "normal pilot" (normal is a relative term here.... if you're a pilot, lots of peeps think we're abnormal.... sigh). Tail water ballast can be useful when dumping wing water ballast creates a CG issue. Just my $0.02US........ -- Dan Marotta |
NIMH batteries - slightly OT | Martin Gregorie[_4_] | Soaring | 13 | April 15th 09 03:17 AM |
NIMH Batteries | K M | Soaring | 23 | December 9th 08 09:27 PM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
C & D NiMH Best Deal | Larry | Home Built | 6 | October 1st 04 01:41 PM |
AA NiMH Best Deal | Jim Weir | Home Built | 27 | September 29th 04 08:39 PM |
