I have cut a lot of fiberglass on waterjets. It will delaminate a small circle around the hole pierce, this can be avoided by drilling thru holes where they can start the cut. A backing board will not prevent it, it is a consequence of the waterjet pressure forcing between the laminate layers before the pierce is complete. The edge will be very nice and clean. You can also cut the panel in a conventional CNC machine, however fiberglass is pretty abrasive and so many CNC shops don't want to deal with it (dust gets into the machinery and wears it out). I will cut it on my open mill so I can vacuum up the dust and chips as it is cutting (but I still don't like it), I will not put in the VMC with coolant etc. - no way to collect the dust.
Trying to fill some holes in the instrument panel | [email protected] | Soaring | 2 | February 12th 14 02:55 AM |
Cutting 57mm holes in the instrument panel.....how to? | John Bojack[_2_] | Soaring | 20 | November 12th 10 09:15 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Cutting shirttails??? | Larry Dighera | Soaring | 11 | September 3rd 03 03:34 PM |
