Combining vario and radio output into one speaker
Old February 27th 15, 05:40 AM posted to rec.aviation.soaring
Paul B[_2_]
Default Combining vario and radio output into one speaker
On Friday, 27 February 2015 15:05:45 UTC+10, Bruce Hoult wrote:
Now you're getting fancy :-)
Thanks Bruce
The fancy is what I want to avoid, as the initial idea was to simplify things - i.e. one speaker instead of four .
Cheers
Paul
Old February 27th 15, 06:30 AM posted to rec.aviation.soaring
Darryl Ramm
Yes but the stuff you are linking to is *irrelevant*. These circuits are talking about driving line level inputs. Those line level inputs have ~tens of kohm input impedance -- that is not at all what you are trying to do. You are trying to blend a signal that is driving a very low impedance (nominally 4 ohm or 8 ohm) speaker. If you want to blend low output impedance signals to drive something like a speaker you need to buffer that low impedance, which gets you into an op amp or similar buffer on each channel and and/or drive a summing amplifier directly, then a power driver circuit. Basically you are building an active audio panel. All that complexity and need to power it and have yet another thing to fail.
The simple solution is use two speakers. Not hard at all.
Thanks Bruce
Cheers
Paul
Old February 27th 15, 07:00 AM posted to rec.aviation.soaring
Bruce Hoult
Thanks Bruce
Well, the good news is all those bits (except volume controls with knobs) would cost less than $10 in total and fit on a board a maximum of a couple of square inches in size.
Heh. These days you could use a $2 ATtiny85 microcontroller in an 8 pin DIP package. 20 MHz CPU. 3 10 bit analog to digital inputs. Scale and add them digitally. Output a pulse-width modulated 1 bit signal at 50 KHz or so, low pass filter (i.e. a resistor and a capacitor), then to the amplifier.
https://learn.sparkfun.com/tutorials...ny85-use-hints
OK, I'm being silly.
Old February 27th 15, 07:03 PM posted to rec.aviation.soaring
Dan Marotta
I feel absolutely old-fashioned what with my vario speaker velcroed to
the top of my glare shield and my radio speaker mounted to the bulkhead
behind my right ear. But, hey! It works.
Thanks Bruce
Dan Marotta
Old February 28th 15, 12:38 AM posted to rec.aviation.soaring
son_of_flubber
bulkhead behind my right ear.
Is it better to have the radio audio output balanced between both ears? I assume that this would result in higher comprehension of radio calls with lower sound pressure (DB) driving each ear. If the speaker drives both ears equally, can you turn down the volume and get the same or better comprehension?
Is it better for the radio speaker(s) to have line of sight to the ears rather than bouncing the sound energy off the hard surfaces in the glider?
My thought is that the best solution is TWO small speakers each with line of sight to one ear. If the audio output bounces off a variety of hard surfaces, the echos will combine and make the signal that reaches the ears 'fuzzy'. So higher sound pressure will be needed.
So why do I want to minimize sound pressure? Hearing loss from exposure to high sound pressure is incremental and cumulative. The first step is to reduce wind noise in the cockpit. But the squeals coming over the air from malfunctioning radios are still pretty loud. Loud enough to be annoying and maybe loud enough to cause a tiny accumulating bit of hearing loss. There is no reason to not turn the radio down as low as feasible.
The vario can have one speaker buried anywhere. Unless you have one of those talking varios... a beep is a beep.
Old February 27th 15, 08:51 PM posted to rec.aviation.soaring
Darryl Ramm
Thanks Bruce
Oh come on, where is your ambition? Once you go digital there are lots of great options. You could add a digital parametric EQ, MIDI programming to customize the vario output, etc.
What is wrong with this industry and lack of innovation? Why has no vario developer offered MIDI output until now?
Old February 27th 15, 11:11 PM posted to rec.aviation.soaring
Bruce Hoult
Thanks Bruce
If you're going to do all that, you might need a more powerful CPU -- how about a full 32 bit ARM in an 8 pin DIP package for about the same price?
https://learn.adafruit.com/getting-s...pc810?view=all
Vario and Radio on a common speaker? Bastoune Soaring 9 March 31st 13 05:43 PM
Radio and Vario For Sale [email protected] Soaring 1 January 13th 11 06:41 PM
Common speaker for vario and radio toad Soaring 15 April 18th 05 04:50 AM
Combining MEK with Plexiglass - good or bad? [email protected] Owning 0 June 24th 04 06:09 AM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 06:09 AM
