new wingtip design
Old February 27th 15, 09:47 PM posted to rec.aviation.soaring
Default new wingtip design
It's an almost 5 year old article.
Never heard of it before, it was so good, we all would have likely heard more about it.
My understanding is the tip vortex is based mostly on wingloading, the higher the loading the worse the vortex is (everything else remaining the same).
Some airfoils & aspect ratio's are worse than others in terms of vortex with a similar wingloading. And yes, speed has an effect as well.
I would like to see the actual tests performed between a "plain tip", winglet and this device.
Old February 27th 15, 10:20 PM posted to rec.aviation.soaring
I did a Google search for "Minix wing tip"
Came up with....
https://www.google.com/search?q=%22M...sm=93&ie=UTF-8
This page (out of the 1st link) is sorta interesting (it's on page 3 of the above search).
http://www-mip.onera.fr/projets/Wake...Durston%5D.pdf
Most of the pages are old, the "newer ones" basically regurgitated the older info......
Curious on what others here think/feel/know......
Old February 27th 15, 11:25 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Snip...
Think/feel...
These sorts of things are what happens when intuition is applied inaptly, kind
of like those early schemes proposing ways for making balloons dirigible, i.e.
steerable...you know, oars and sails and the like. How does this magical
"unwinding" device go about capturing the entire pressure differential between
bottom & top of the wing so's to prevent vorticity developing? Methinks at the
very least a considerably larger bell-mouth is in order to have potential for
ANY detectable vortical disruption. :-)
Quite Possibly/Presumably In the "Know Dep't." (Copied from comments)
"I tested this device for my university thesis and it done nothing at all but
to increase drag due to the extra skin friction drag caused by a greater
surface area. The vortices do not reduce because the design considers the
physics on too primitive and intuitive a level."
James Fletcher
26th March, 2012 @ 01:58 pm PDT
Old February 28th 15, 01:30 AM posted to rec.aviation.soaring
Craig Funston
Snip...
Think/feel...
James Fletcher
Excellent discussion of "Common Misconceptions in Aerodyanmics" Worth the time to listen to the whole thing.
https://www.youtube.com/watch?v=QKCK...bn0iDCBbgpLbX6
Craig
Old February 28th 15, 03:34 AM posted to rec.aviation.soaring
BobW
Snip...
Think/feel... These sorts of things are what happens when intuition is
applied inaptly, kind of like those early schemes proposing ways for
making balloons dirigible, i.e. steerable...you know, oars and sails and
the like. How does this magical "unwinding" device go about capturing the
entire pressure differential between bottom & top of the wing so's to
prevent vorticity developing? Methinks at the very least a considerably
larger bell-mouth is in order to have potential for ANY detectable
Quite Possibly/Presumably In the "Know Dep't." (Copied from comments) "I
but to increase drag due to the extra skin friction drag caused by a
greater surface area. The vortices do not reduce because the design
considers the physics on too primitive and intuitive a level." James
Fletcher 26th March, 2012 @ 01:58 pm PDT
Craig
Great lecture - wish I'd had more like this in collich!
The aero engineer in me is still laughing at: "It's easy to explain how a
rocket works, but explaining how a wing works takes a rocket scientist."
Making it even funnier is that I used the degree for the first 4 years after
school in the solid rocket motor industry, where "rocket scientist" jokes were
rife...and decades later, non-aerodynamiscist-me is still trying to refine my
understanding/explanation for lift and its generation! Considering sailplanes,
I'm presently a fan of: gravity causes lift - after that things become
complicated! :-)
Bob W.
A wingtip Glenn[_2_] Aviation Photos 5 September 3rd 10 03:33 PM
Yet another PA-28 wingtip query... Mike Spera Owning 2 August 4th 09 03:07 AM
Wingtip Camera NG[_2_] Soaring 14 April 9th 09 11:38 PM
Wingtip Camera kestrel19 Soaring 0 April 9th 09 04:02 PM
L-23 wingtip wheel modification 5Z Soaring 0 February 8th 06 05:50 PM
