On Saturday, February 28, 2015 at 6:10:30 PM UTC-5, MNLou wrote:
Hey Dan - Why not just use water for tail ballast and not have so much weight up high? Possibly a freezing problem at altitude? Water can be good to offset the balance when dumping wing ballast..... If he is looking at "static balance" (my choice of words).... he is looking at fixed ballast for the "normal pilot" (normal is a relative term here.... if you're a pilot, lots of peeps think we're abnormal.... sigh). Tail water ballast can be useful when dumping wing water ballast creates a CG issue. Just my $0.02US........ |
Exactly right, Charlie!
I've chosen to add an extra 4 lb of lead to the tail battery box because, with dry wings and tail, my current CG is at 71% aft and that requires most of my aft trim capability, full aft trim for thermalling below about 50 KIAS. The extra 4 lb moves the CG back to 79% aft which should give me one or two notches on the trimmer and should be just fine during the winter months. In the summer, I can supplement the tail weight with the tail tank to move the CG back into the 90s. According to my W&B spreadsheet, I can trim to 92% aft at gross weight. That satisfies me. On 2/28/2015 4:41 PM, Charlie M. (UH & 002 owner/pilot) wrote: On Saturday, February 28, 2015 at 6:10:30 PM UTC-5, MNLou wrote: Hey Dan - Why not just use water for tail ballast and not have so much weight up high? Possibly a freezing problem at altitude? Water can be good to offset the balance when dumping wing ballast..... If he is looking at "static balance" (my choice of words).... he is looking at fixed ballast for the "normal pilot" (normal is a relative term here.... if you're a pilot, lots of peeps think we're abnormal.... sigh). Tail water ballast can be useful when dumping wing water ballast creates a CG issue. Just my $0.02US........ -- Dan Marotta |
NIMH batteries - slightly OT | Martin Gregorie[_4_] | Soaring | 13 | April 15th 09 03:17 AM |
NIMH Batteries | K M | Soaring | 23 | December 9th 08 09:27 PM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
C & D NiMH Best Deal | Larry | Home Built | 6 | October 1st 04 01:41 PM |
AA NiMH Best Deal | Jim Weir | Home Built | 27 | September 29th 04 08:39 PM |
