PowerFLARM parameters for Silver badge?
Old March 6th 15, 05:32 PM posted to rec.aviation.soaring
Bob Pasker
Default PowerFLARM parameters for Silver badge?
thanks, most helpful answer yet. i'm not ready to do distance, just altitude gain and duration, so I don't yet have to worry about the declaration.
On Friday, March 6, 2015 at 11:24:30 AM UTC-5, Dan Daly wrote:
On Friday, March 6, 2015 at 11:05:18 AM UTC-5, Bob Pasker wrote:
thanks. unfortunately, i cant fill out the form until I know all the parameters, and that won't happen till I'm at the airport
Similar problem at our club - 3 flarm-fitted club gliders. Members fill out multiple declarations, and use the one for the glider they fly. The flarmcfg - Tool is very easy to use. The type of glider and registration should be available. Class is important for records only. For PowerFLARM, 4 seconds gives a nice looking trace and keeps data records smaller. The declaration is last - this is our club std 50 km flight (takeoff, start, turnpoint, finish, landing) for a 100km out and return). Creating it takes only a few seconds... Keep all in folders for each a/c (or have a different USB stick for each) and move a single flarmcfg.txt file to the highest level of the stick. Insert into usb slot, turn on, let load, go fly, download file, bask in the adulation of your peers.
Here's what the output of the flarm tool looks like; note, it doesn't change flarm or transponder settings - only declaration things.
//FLARM configuration file created with flarmcfg - Tool
//�2009-2011 powered by www.Segelflug-Software.de
//am: 23/02/2014 um 10:06:23 AM
//Pilot Name
$PFLAC,S,PILOT,Daniel Daly
//Co-Pilot Name
$PFLAC,S,COPIL,
//Aircraft Type
$PFLAC,S,GLIDERTYPE,SZD 55
// Aircraft registration
$PFLAC,S,GLIDERID,C-GXDD
//Competition ID
$PFLAC,S,COMPID,2D
//Competition class
$PFLAC,S,COMPCLASS,Club
//Logger interval
$PFLAC,S,LOGINT,4
//Task declaration
$PFLAC,S,NEWTASK,silver d
$PFLAC,S,ADDWP,4529250N,07505650W,01Pendle
$PFLAC,S,ADDWP,4538383N,07422217W,80Lachut
Old March 6th 15, 06:02 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I'd recommend that you get used to doing declarations on every flight; then, when Silver Distance day comes, it will be a habit, and not another detail on what will be a hectic day. If you get in the habit of inserting declarations and downloading the files, you will be able to analyze your flying against others ("how did she stay up when I could not?") and gain OLC points (OLC is a great place to store flights for later).
Paper declarations are good for initial attempts; however, the table in Appendix 2 to Annex C of the Sporting Code indicates you don't need one for Silver Height or Duration - just fly the flight and download the file for the Height, and use either the file or a Certificate of Continuous Observation for the Duration...
Annex C is very readable. Recommended reading.
Old March 7th 15, 12:04 PM posted to rec.aviation.soaring
Flights downloaded from OLC have been altered. They will not verify and therefore are not valid for badges.
Walter
Old March 6th 15, 08:24 PM posted to rec.aviation.soaring
Darryl Ramm
As you start exploring XC I would try to start making declarations, just for the experience to see how it works, and get used to all the extra complexity associated with different starts and finishes etc. Once you think you've done even the shortest declared flight, download it and play in SeeYou and see if you think the flight really qualifies...
Silver Badge questions Bob Pasker Soaring 31 February 22nd 15 08:23 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 4 August 20th 13 04:37 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 0 August 20th 13 02:47 AM
Silver Badge! [email protected] Soaring 17 November 24th 08 03:12 AM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
