Boost performance of Solo 2350 turbo (sustainer)
Old March 7th 15, 08:26 AM posted to rec.aviation.soaring
John Galloway[_1_]
Default Boost performance of Solo 2350 turbo (sustainer)
I have de-restricted a Discus BT and a Discus 2cT as described below. The
climb rate definitely improves but not as much as reported - from averaging
timed climbs and post flight analysis of flight recorder data I reckon you
get
about half a knot increase to average of 2.9 knots. Its still a worthwhile
improvement but you have to be aware the regulatory and possible
insurance considerations.
John Galloway
At 23:30 06 March 2015, Charlie Papa wrote:
On Friday, March 6, 2015 at 2:14:12 AM UTC-5,
Wondering if anyone has boosted the horsepower of a Solo 2350 turbo
(or
s=
ustainer engine) to get better high and hot performance? If anyone has
don=
e this would like both positive and negative comments as to the work
done,
the results and what they did to boost engine performance.
Yes indeed, I have done it. It is not to INCREASE the horsepower so much
a=
s it is to RESTORE the horsepower that the 2350 was originally built to.
I=
t was de-tuned by tack welding a pair of constricting rings into the
exhaus=
t, and then reducing the jet size by one. =20
Mine is installed in a Discus 2cT, and as such, it is a sustainer. That
me=
ans no throttle, no choke, no generator, - just the simplest get-you-home
a=
nd lightest possible. If I understand correctly, the LBA required that
it
be able to sustain level flight, presumably in controlled airspace. With
t=
he full 28 HP it was built to, in level flight it would overspeed, which
cu=
ts off the ignition. =20
But using it in controlled space requires the use of headphones; a
non-star=
ter for me. I just stay out of controlled space. However, with the
horsep=
ower estored from the diminished 22 to 28, does it climb better. You
bette=
r believe it.
The restrictor rings are tack welded in and very vulnerable to a Dremmel
to=
ol. Then you must remove the two jets, move the larger one in the rear
(lar=
ger to overcome how much hotter it will run with already heated air from
th=
e front cylinder passing over it) and move it to the front, and then put
th=
e next larger size in the rear. =20
Don't mix up the covers for the pulse diaphragm that 'injects' the
air/fuel=
; the front one should not have the hole that would make it vulnerable to
t=
he prop wash.
The result: MUCH improved climb, - perhaps 300 - 350/fpm vs. ~200.
Hard
to=
be exact as the vibration shakes the hell out of the varios. =20
And in ~1100 hours, there is less than 10 hours on the engine, because it
i=
s just a sustainer, and because I start it right off tow each day
(because
it's complicated and it starts faster if it has already run.
solo 2350 engines Rocket Soaring 3 January 24th 07 03:58 PM
Help with Solo 2350 Limus Soaring 2 May 3rd 06 02:15 AM
Duo Turbo Climb / Altitude performance Gary Emerson Soaring 16 November 28th 05 08:19 AM
Turbo performance vs non-turbo John Doe Owning 22 October 8th 05 02:34 AM
Solo 2350 Engine Overhaul Manual - Translation Requested Bob Gibbons Soaring 2 January 10th 04 08:45 AM
